I am using Jetson TX2 4GB since 2 years. So far, I have used about 50 modules and recently on new modules I have problems with CAN communication.
My setup :
Jetson TX2 modules with connect tech quasar mother board. The can transceiver is on the quasar board and we add a 120 ohm resistor.
L4T release : # R32 (release), REVISION: 2.1, GCID: 16294929, BOARD: t186ref, EABI: aarch64, DATE: Tue Aug 13 04:45:36 UTC 2019
Can ECU with another 120 ohm resistor.
Can configuration :
The CAN is configured when the JTX2 module is booted with a rc.local script. The script :
modprobe can
modprobe can_raw
modprobe mttcan
ip link set can0 type can bitrate 250000 sjw 4 loopback off restart-ms 1000
sleep 1
ifconfig can0 up
So far, I have never had a problem with the CAN communication. Everything worked perfectly. In March, I received 26 new JTX2 modules and for some of them, when starting up, the CAN bus configuration does not work. It is necessary to restart the module to hope to have a good configuration. On the other hand, when the communication initializes well, it works perfectly and is very stable. The problem seems to be completely random.
Here is the console message (with dmesg
) when the initialization failed :
[ 10.744138] can: controller area network core (rev 20120528 abi 9)
[ 10.744850] NET: Registered protocol family 29
[ 10.761540] can: raw protocol (rev 20120528)
[ 10.779520] CAN device driver interface
[ 10.801803] Message RAM Configuration
| base addr |0x0c312000|
| sidfc_flssa |0x00000000|
| xidfc_flesa |0x00000040|
| rxf0c_f0sa |0x000000c0|
| rxf1c_f1sa |0x000009c0|
| rxbc_rbsa |0x000009c0|
| txefc_efsa |0x000009c0|
| txbc_tbsa |0x00000a40|
| tmc_tmsa |0x00000ec0|
[ 10.801982] Release 3.2.0 from 19.12.2014
[ 10.802341] net can0: mttcan device registered (regs=ffffff8008024000, irq=387)
[ 10.806685] Message RAM Configuration
| base addr |0x0c322000|
[ 10.806864] Release 3.2.0 from 19.12.2014
[ 10.807311] net can1: mttcan device registered (regs=ffffff800a4e1000, irq=388)
[ 10.814313] mttcan c310000.mttcan can0: Bitrate set
[ 11.832780] mttcan_controller_config: ctrlmode 0
[ 11.832812] mttcan c310000.mttcan can0: Bitrate set
[ 12.275320] mttcan c310000.mttcan can0: entered error warning state
[ 12.281774] mttcan c310000.mttcan can0: entered error passive state
and the CAN link details ans statistics :
$ ip -details -statistics link show can0
7: can0: <NOARP,UP,LOWER_UP,ECHO> mtu 16 qdisc pfifo_fast state UNKNOWN mode DEFAULT group default qlen 10
link/can promiscuity 0
can state ERROR-PASSIVE (berr-counter tx 0 rx 127) restart-ms 1000
bitrate 250000 sample-point 0.875
tq 25 prop-seg 69 phase-seg1 70 phase-seg2 20 sjw 4
mttcan: tseg1 2..255 tseg2 0..127 sjw 1..127 brp 1..511 brp-inc 1
mttcan: dtseg1 1..31 dtseg2 0..15 dsjw 1..15 dbrp 1..15 dbrp-inc 1
clock 40000000
re-started bus-errors arbit-lost error-warn error-pass bus-off
0 0 0 1 1 0 numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
RX: bytes packets errors dropped overrun mcast
16 2 0 0 0 0
TX: bytes packets errors dropped carrier collsns
0 0 0 0 0 0
For the same module, when the initialization works :
[ 6.729004] can: controller area network core (rev 20120528 abi 9)
[ 6.730891] NET: Registered protocol family 29
[ 6.737004] can: raw protocol (rev 20120528)
[ 6.750243] CAN device driver interface
[ 6.757261] Adding 327256k swap on /dev/zram0. Priority:5 extents:1 across:327256k SS
[ 6.759900] zram1: detected capacity change from 0 to 335114240
[ 6.781547] Message RAM Configuration
[ 6.781719] Release 3.2.0 from 19.12.2014
[ 6.782088] net can0: mttcan device registered (regs=ffffff8008026000, irq=387)
[ 6.790250] Message RAM Configuration
[ 6.790480] Release 3.2.0 from 19.12.2014
[ 6.790960] net can1: mttcan device registered (regs=ffffff800a1bd000, irq=388)
[ 6.797075] mttcan c310000.mttcan can0: Bitrate set
[ 6.816003] Adding 327256k swap on /dev/zram1. Priority:5 extents:1 across:327256k SS
[ 6.838691] zram2: detected capacity change from 0 to 335114240
[ 6.862387] Adding 327256k swap on /dev/zram2. Priority:5 extents:1 across:327256k SS
[ 6.873756] zram3: detected capacity change from 0 to 335114240
[ 6.908520] Adding 327256k swap on /dev/zram3. Priority:5 extents:1 across:327256k SS
[ 6.910977] zram4: detected capacity change from 0 to 335114240
[ 6.923284] Adding 327256k swap on /dev/zram4. Priority:5 extents:1 across:327256k SS
[ 6.931756] zram5: detected capacity change from 0 to 335114240
[ 6.960417] Adding 327256k swap on /dev/zram5. Priority:5 extents:1 across:327256k SS
[ 7.817117] mttcan_controller_config: ctrlmode 0
[ 7.817150] mttcan c310000.mttcan can0: Bitrate set
can state ERROR-ACTIVE (berr-counter tx 0 rx 0) restart-ms 1000
clock 40000000
0 0 0 0 0 0 numtxqueues 1 numrxqueues 1 gso_max_size 65536 gso_max_segs 65535
45304 5663 0 0 0 0
9792 1224 0 0 0 0
I did many different tests before I found that the Jetson TX2 module was the problem. I tested my system with :
- 3 different ECU
- 3 different cables
- 2 different mother board
- 3 different power supply (in case of perturbation)
I also try to re-flash JTX2 4 GB module multiple time and clone the system from a working module to a none working module.
In addition, I also tested to reconfigure the CAN communication if it’s failed but it does not work. The only thing we can do, it is to reboot the module.
Over the 26 new JTX2 4GB modules I received in march, I test 8 modules. Over the 8 modules, I found 3 modules with the problem but there are probably more over the 26. The serial number of the 3 modules begin with “142082205xxxx”.
After all these tests, some modules initialize correctly all the time and others have initialization problems (The problem occurs between 30% and 50% of the time). So I’m pretty sure that the problem is hardware and comes from the Jetson TX2 4 GB modules.
Maybe I can make some other test if someone have an idea ?
Have you had similar feedback from other users?
Did you have production problems on some series?
Regards,
Frédéric
