With the JetPack 4.2.1 we see random CPU sErrors with our custom carrier board. The corresponding log is attached. Sometimes the system boots normally without error.
In JetPack 3.3, we never saw this errors.
What could be the cause?
Thank you.
We narrowed the problem down. It seems that the pinmux config creates the problem. Can you confirm that the new pinmux sheet from 15.04.2019 Revision 1.00 has to be used with JetPack 4.2.2 and that the older spreadsheet from 02.11.2018 Revision 1.08 cannot be used?
Thank you.
We are using the latest pinmux sheet now, but still face some problems.
When we do not change anything in the sheet and create the dtsi files and from them the cfg files, the system is booting very slowly (~3min) and also reacting very slow.
If we use the tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg, the system boots normally and the system works without any problems.
Is the default configuration of the Spreadsheet not the same like the tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg? Checking the generated file with the reference, it seems not to be. What is changed?
At least we do not see the kernel panics anymore.
Thank you for your help.
