I am getting a double free or corruption (out)
error when capturing images from three cameras on the Jetson TX2. The backtrace shows that this occures inside the libnvscf.so
(gdb) where
#0 __GI_abort () at abort.c:107
#1 0x0000007f7f5f868c in __libc_message (action=action@entry=do_abort, fmt=fmt@entry=0x7f7f6b96f8 "%s\n") at ../sysdeps/posix/libc_fatal.c:181
#2 0x0000007f7f5fea04 in malloc_printerr (str=str@entry=0x7f7f6b53d8 "double free or corruption (out)") at malloc.c:5342
#3 0x0000007f7f600664 in _int_free (av=0x7f7f6dfa70 <main_arena>, p=0x7f7b507920, have_lock=<optimized out>) at malloc.c:4308
#4 0x0000007f7aee9288 in ?? () from /usr/lib/aarch64-linux-gnu/tegra/libnvscf.so
#5 0x0000007f7af422d4 in ?? () from /usr/lib/aarch64-linux-gnu/tegra/libnvscf.so
#6 0x0000007f7af476dc in ?? () from /usr/lib/aarch64-linux-gnu/tegra/libnvscf.so
#7 0x0000007f7af4b6c8 in ?? () from /usr/lib/aarch64-linux-gnu/tegra/libnvscf.so
#8 0x0000007f7af1de58 in ?? () from /usr/lib/aarch64-linux-gnu/tegra/libnvscf.so
#9 0x0000007f7ad44628 in ?? () from /usr/lib/aarch64-linux-gnu/tegra/libnvos.so
#10 0x0000007f7f95d088 in start_thread (arg=0x7fc306a30f) at pthread_create.c:463
#11 0x0000007f7f65bffc in thread_start () at ../sysdeps/unix/sysv/linux/aarch64/clone.S:78
(gdb) bt full
act = {__sigaction_handler = {sa_handler = 0x0, sa_sigaction = 0x0}, sa_mask = {__val = {18446744073709551615 <repeats 16 times>}}, sa_flags = 0, sa_restorer = 0x0}
sigs = {__val = {32, 0 <repeats 15 times>}}
ap = {__stack = 0x7f6df36f50, __gr_top = 0x7f6df36f50, __vr_top = 0x7f6df36f20, __gr_offs = -40, __vr_offs = 0}
fd = <optimized out>
list = <optimized out>
nlist = <optimized out>
cp = <optimized out>
written = <optimized out>
No locals.
size = 367832723872
fb = <optimized out>
nextchunk = 0xd51fda6ac0
nextsize = <optimized out>
nextinuse = <optimized out>
prevsize = <optimized out>
bck = <optimized out>
fwd = <optimized out>
__PRETTY_FUNCTION__ = "_int_free"
No symbol table info available.
pd = 0x7fc306a30f
unwind_buf = {cancel_jmp_buf = {{jmp_buf = {547305521424, 548732838672, 548732838670, 548732838671, 0, 4096, 548732838672, 547601502208, 547305521424, 1, 547305519376, 4506411868204586633, 0, 4506411867896741829, 0, 0, 0, 0, 0,
0, 0, 0}, mask_was_saved = 0}}, priv = {pad = {0x0, 0x0, 0x0, 0x0}, data = {prev = 0x0, cleanup = 0x0, canceltype = 0}}}
not_first_call = <optimized out>
No locals.
(gdb)
The crash is random. Sometimes it happens after some minutes, sometime it take multiple hours. This is happening with L4T 32.5.1. On L4T 32.3.1, we didn’t saw this behavior.
I would appreciate if someone could help me to solve this issue.
