Random packet loss when using raw packet QPs and L2 flows
Hello there,
I wanted to stress test my CX3 cluster. To do so, I am using the example applications provided here: Raw Ethernet Programming: Basic Introduction - Code Example. https://community.mellanox.com/s/article/raw-ethernet-programming--basic-introduction---code-example Except that instead of an ICMP packet the sender sends a raw ethernet payload (EtherType == 8) with an incrementing counter. I also added an extra wait time at the send of the send.
With that setup I am noticing random packet loss (i.e. non-sequential counters) on the receiver side. The faster the rate (ie. the smaller the extra wait time) the larger the gaps in sequence numbers. My QPs are large enough (1000s of WR) and I do not run into any queue overrun. Besides, the problem also appear with very slow rates (~1pkt/s).
I’ve tried to update all drivers/firmwares, to no avail. Here is my configuration:
Machine A
Device Type: ConnectX3Pro
Part Number: MCX314A-BCC_Ax
Description: ConnectX-3 Pro EN network interface card; 40GigE; dual-port QSFP; PCIe3.0 x8 8GT/s; RoHS R6
PSID: MT_1090111023
PCI Device Name: 0000:81:00.0
Port1 MAC: 248a0772ca40
Port2 MAC: 248a0772ca41
Versions: Current Available
FW 2.42.5000 2.40.7000
PXE 3.4.0752 3.4.0746
Machine B
Part Number: MCX354A-FCB_A2-A5
Description: ConnectX-3 VPI adapter card; dual-port QSFP; FDR IB (56Gb/s) and 40GigE; PCIe3.0 x8 8GT/s; RoHS R6
PSID: MT_1090120019
PCI Device Name: 0000:0b:00.0
Port1 MAC: 7cfe90bed011
Port2 MAC: 7cfe90bed012
Both machines use the Mellanox OFED drivers version 4.2-1.2.0.0 and runs RHEL 7.3 with kernel 3.10.0-514.6.1.el7.x86_64.
Any help would be welcomed
