Hi, I have a stereo setup with 3 cameras. I defined the cameras in the .usd file and make them children of an Xform called “stereo_cam”. Then, I randomized this Xform according to following code:
It works fine and I can generate data with that. The next step is to have a trajectory for each of the points (that have been chosen randomly by rep.modify.pose). My idea is to get the pose of “stereo_cam” at each randomly chosen point and modify the pose with rep.modify.pose again (double loop) such that the camera follow the trajectory (let’s say trajectory is to go in a y direction 30 timesteps and each time y increase by 5cm).
The problem is that when I detect the “stereo_cam” in the code by:
stereo_cam = rep.get.prims(path_pattern=“/Replicator/Ref_Xform/Ref/stereo_cam”)
Its type is “ReplicatorItem” and I can not find a way to obtain its pose.
I have 2 specific questions:
- How can I get the pose of the ReplicatorItem object?
- Does my idea for generating data with a randomized camera that also follows a specific trajectory make sense, or there is a better way to do that?
Thank you very much.
