I am trying to randomize the color of floor (say only once and not triggered every frame). I am following this tutorial:
def main():
# Open the environment in a new stage
print(f"Loading Stage {ENV_URL}")
open_stage(prefix_with_isaac_asset_server(ENV_URL))
# Create a custom scope for newly added prims
stage = get_current_stage()
floor_prims = [x.GetPath() for x in stage.Traverse() if "SM_floor" in x.GetName() and prims_utils.get_prim_type_name(x.GetPath()) == "Xform"]
with floor_prims:
rep.randomizer.color(colors=rep.distribution.uniform((0, 0, 0), (1, 1, 1)))
Here’s the error I got:
2023-02-21 14:15:41 [16,367ms] [Warning] [rtx.neuraylib.plugin] Compiler Core: omniverse://localhost/NVIDIA/Assets/Isaac/2022.2.0/NVIDIA/Assets/Characters/Reallusion/Worker/Materials/OmniRL_PBR.mdl?watch=00007f2bf2290410(111,19): C183 unused parameter 'emissive_intensity'
2023-02-21 14:15:42 [16,984ms] [Warning] [omni.isaac.core.simulation_context.simulation_context] A new stage was opened, World or Simulation Object are invalidated and you would need to initialize them again before using them.
2023-02-21 14:15:42 [17,033ms] [Error] [__main__] Exception: __enter__
File "/home/mona/SDG/omniverse-sdg/offline_generation.py", line 711, in <module>
main()
File "/home/mona/SDG/omniverse-sdg/offline_generation.py", line 425, in main
with floor_prims:
AttributeError: __enter__
[17.177s] Simulation App Shutting Down
I also tried this other version and still same error:
def main():
for floor_prim in floor_prims:
with floor_prim:
# with floor_prims:
# rep.randomizer.color(colors=rep.distribution.uniform((0, 0, 0), (1, 1, 1)))
Error is:
2023-02-21 14:20:12 [15,960ms] [Warning] [rtx.neuraylib.plugin] Compiler Core: omniverse://localhost/NVIDIA/Assets/Isaac/2022.2.0/NVIDIA/Assets/Characters/Reallusion/Worker/Materials/OmniRLBase.mdl?watch=00007f2212e02bb0(102,32): C302 conversion from 'float' to 'float3' must be explicit
2023-02-21 14:20:12 [15,960ms] [Warning] [rtx.neuraylib.plugin] Compiler Core: omniverse://localhost/NVIDIA/Assets/Isaac/2022.2.0/NVIDIA/Assets/Characters/Reallusion/Worker/Materials/OmniRL_PBR.mdl?watch=00007f2182355880(111,19): C183 unused parameter 'emissive_intensity'
2023-02-21 14:20:13 [16,575ms] [Warning] [omni.isaac.core.simulation_context.simulation_context] A new stage was opened, World or Simulation Object are invalidated and you would need to initialize them again before using them.
2023-02-21 14:20:13 [16,624ms] [Error] [__main__] Exception: __enter__
File "/home/mona/SDG/omniverse-sdg/offline_generation.py", line 718, in <module>
main()
File "/home/mona/SDG/omniverse-sdg/offline_generation.py", line 427, in main
with floor_prim:
[16.791s] Simulation App Shutting Down
