Rapids Libraries on RedHat
Hi, are Rapids Libraries also supported on red hat OS ?
Yes.
NOTE: RHEL 7 & 8 conda support is provided by builds and tests on CentOS 7 or 8.
The same conda create commands should work with gcc >=7.5 and the correct NVIDIA and CUDA drivers.
thank you Matt. does RH also supports (like ubuntu) dual GPU configurations ? (like on DSWS configurations)
I’m not sure I follow… Are you asking if you can have separate model GPU in the same system? If yes, I don’t see why not.
I mean, for example, 2 x rtx8000 (with or without hw nvlink). I remember some restrictions on linux drivers, but not sure.
I’m not aware of such restrictions.
