Hi, NV team,
We met xavier suddenly reboot problem on our own design carrier board.
JP version:# R32 (release), REVISION: 4.4, GCID: 23942405, BOARD: t186ref, EABI: aarch64, DATE: Fri Oct 16 19:37:08 UTC 2020
Before reboot ,there are many RAS errors in the kernel log, just as shown below.
My question are:
what do these errors mean? Is this what caused the system to reboot?
How did you get the RAS FHI error? Any test running on device?
The JetPack version 4.4 is a bit old.
Also this issue happened on your custom board, can you reproduce it at newer version, such as JetPack 4.6?
Hi, That errors are the same that if the memory is under radiation testing. I don’t think is the case.
But could be that you are writing the register that triggers RAS errors or that your custom board is writing on that address.
Try to see if you a writhing to this address.
sys/kernel/debug/carmel_ras/RAS_MCA_ERR-trip
0xff00000000
