After several power cycles of the Jetson Orin Nano, It shows the following error:
NOTICE: BL31: v2.8(release):e12e3fa93
NOTICE: BL31: Built : 17:14:28, Jan 7 2025
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 4.2 (gcc version 11.3.0 (Buildroot 2022.08)) #2 Wed Jan 8 01:24:03 UTC 2025 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: fTPM ID is not enabled.
I/TC: ftpm-helper PTA: fTPM DT or EKB is not available. fTPM provisioning is not supported.
I/TC: Primary CPU switching to normal world boot
Jetson UEFI firmware (version 36.4.3-gcid-38968081 built on 2025-01-08T01:18:20+00:00)
I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
E/TC:?? 00
E/TC:?? 00 User mode data-abort at address 0x40 (translation fault)
E/TC:?? 00 esr 0x92000005 ttbr0 0x40000be291000 ttbr1 0x00000000 cidr 0x0
E/TC:?? 00 cpu #0 cpsr 0x60000000
E/TC:?? 00 x0 0000000000000000 x1 0000000000001000
E/TC:?? 00 x2 0000000000001000 x3 0000000040707bd0
E/TC:?? 00 x4 0000000040584010 x5 00000000406df568
E/TC:?? 00 x6 0000000000000040 x7 0000000000000040
E/TC:?? 00 x8 0000000000000040 x9 0000000000000000
E/TC:?? 00 x10 0000a00000001000 x11 0000000000000040
E/TC:?? 00 x12 0000000000000000 x13 4200004000000000
E/TC:?? 00 x14 0000000000000000 x15 0000000000000000
E/TC:?? 00 x16 000000004004e290 x17 00000000000000f8
E/TC:?? 00 x18 0000000000000000 x19 00000000406eb810
E/TC:?? 00 x20 0000000000000000 x21 0000000040707bd0
E/TC:?? 00 x22 000000000000003f x23 0000000040584010
E/TC:?? 00 x24 0000000000000000 x25 0000000000001000
E/TC:?? 00 x26 00000000406e8000 x27 0000000040584010
E/TC:?? 00 x28 0000000000000000 x29 0000000040707b00
E/TC:?? 00 x30 000000004060ab38 elr 00000000406df5e8
E/TC:?? 00 sp_el0 0000000040707b00
E/TC:?? 00 region 0: va 0x0000000040000000 pa 0x00000000be082000 size 0x002000 flags ---R-X
E/TC:?? 00 region 1: va 0x0000000040002000 pa 0x00000000be264000 size 0x001000 flags ---RW-
E/TC:?? 00 region 2: va 0x0000000040004000 pa 0x00000000be529000 size 0x048000 flags r-xR--
E/TC:?? 00 region 3: va 0x000000004004c000 pa 0x00000000be571000 size 0x001000 flags rw----
E/TC:?? 00 region 4: va 0x000000004004d000 pa 0x00000000be572000 size 0x00b000 flags r-x---
E/TC:?? 00 region 5: va 0x0000000040058000 pa 0x00000000be57d000 size 0x001000 flags rw----
E/TC:?? 00 region 6: va 0x0000000040059000 pa 0x00000000be57e000 size 0x001000 flags r-x---
E/TC:?? 00 region 7: va 0x000000004005a000 pa 0x00000000be57f000 size 0x2aa000 flags r-xR--
E/TC:?? 00 region 8: va 0x0000000040304000 pa 0x00000000be829000 size 0x304000 flags rw-RW-
E/TC:?? 00 region 9: va 0x0000000040608000 pa 0x00000000beb2d000 size 0x008000 flags r-x---
E/TC:?? 00 region 10: va 0x0000000040610000 pa 0x00000000beb35000 size 0x001000 flags rw-RW-
E/TC:?? 00 region 11: va 0x0000000040611000 pa 0x00000000beb36000 size 0x001000 flags r-x---
E/TC:?? 00 region 12: va 0x0000000040612000 pa 0x00000000beb37000 size 0x002000 flags rw-RW-
E/TC:?? 00 region 13: va 0x0000000040614000 pa 0x00000000beb39000 size 0x005000 flags r-x---
E/TC:?? 00 region 14: va 0x0000000040619000 pa 0x00000000beb3e000 size 0x001000 flags rw-RW-
E/TC:?? 00 region 15: va 0x000000004061a000 pa 0x00000000beb3f000 size 0x001000 flags r-x---
E/TC:?? 00 region 16: va 0x000000004061b000 pa 0x00000000beb40000 size 0x0c2000 flags rw-RW-
E/TC:?? 00 region 17: va 0x00000000406dd000 pa 0x00000000bec02000 size 0x00b000 flags r-x---
E/TC:?? 00 region 18: va 0x00000000406e8000 pa 0x00000000bec0d000 size 0x001000 flags rw-RW-
E/TC:?? 00 region 19: va 0x00000000406e9000 pa 0x00000000bec0e000 size 0x001000 flags r-x---
E/TC:?? 00 region 20: va 0x00000000406ea000 pa 0x00000000bec0f000 size 0x003000 flags rw-RW-
E/TC:?? 00 region 21: va 0x00000000406ed000 pa 0x00000000bec12000 size 0x006000 flags r-x---
E/TC:?? 00 region 22: va 0x00000000406f3000 pa 0x00000000bec18000 size 0x001000 flags rw-RW-
E/TC:?? 00 region 23: va 0x00000000406f4000 pa 0x00000000bec19000 size 0x001000 flags r-x---
E/TC:?? 00 region 24: va 0x00000000406f5000 pa 0x00000000bec1a000 size 0x002000 flags rw-RW-
E/TC:?? 00 region 25: va 0x00000000406f7000 pa 0x00000000bec1c000 size 0x005000 flags r-x---
E/TC:?? 00 region 26: va 0x00000000406fc000 pa 0x00000000bec21000 size 0x001000 flags rw-RW-
E/TC:?? 00 region 27: va 0x00000000406fd000 pa 0x00000000bec22000 size 0x001000 flags r-x---
E/TC:?? 00 region 28: va 0x00000000406fe000 pa 0x00000000bec23000 size 0x01f000 flags rw-RW-
E/TC:?? 00 region 29: va 0x000000004071d000 pa 0x00000000bec42000 size 0x015000 flags rw-RW-
E/TC:?? 00 region 30: va 0x0000000040732000 pa 0x000000000c198000 size 0x001000 flags rw----
E/TC:?? 00 region 31: va 0x0000000040733000 pa 0x0000000003270000 size 0x010000 flags rw----
E/TC:?? 00 region 32: va 0x0000000040743000 pa 0x000000000c390000 size 0x002000 flags rw----
ERROR: Exception reason=0 syndrome=0xbe000011
ERROR: **************************************
ERROR: RAS Uncorrectable Error in IOB, base=0xe010000:
ERROR: Status = 0xec000612
ERROR: SERR = Error response from slave: 0x12
ERROR: IERR = CBB Interface Error: 0x6
ERROR: Overflow (there may be more errors) - Uncorrectable
ERROR: MISC0 = 0xc4520040
ERROR: MISC1 = 0x28cc860000000000
ERROR: MISC2 = 0x0
ERROR: MISC3 = 0x0
ERROR: ADDR = 0x8000000003270000
ERROR: sdei_dispatch_event returned -1
I already checked the OPTEE heap size and it is 1024 * SMALL_PAGE_SIZE, the same that it is proposed here: https://forums.developer.nvidia.com/t/orin-nx-hangs-on-optee-r35-5-0/286262/3
I noticed that someone already had this issue before with the same jetpack version (36.4.3) but nobody proposed a solution for that: Orin nano RAS Uncorrectable Error in IOB on R36.4.3 (jetpack6.2) .
Please can you help me to find the error and a reliable way to solve this in our future products using the Jetson Orin Nano?
Regards,
Andres
