Thank you @mdegans and @DavidSoto-RidgeRun,
TLDR; Real exposure time range for sensor mode 1: [34000,33333333]
With @aaronlozhkin:
We did an exhaustive test and here is the story.
- When using gst-launch-1.0 nvarguscamerasrc … it shows that both sensor modes have an exposure range of [13000,683709000]. However, both of those values output a warning ‘invalid time range’, and the camera defaults to some default exposure time.
In:
gst-launch-1.0 nvarguscamerasrc exposuretimerange="13000 13000" wbmode=0 sensor_id=0 sensor-mode=1 ispdigitalgainrange="1 1" aelock=true gainrange="4 4" ! nvoverlaysink
Out:
GST_ARGUS: NvArgusCameraSrc: Setting Exposure Time Range : 13000 13000
GST_ARGUS: Invalid Exposure Time Range Input
The values that don’t produce an error are [34000,358733008]. Suspiciously close to the gst-inspect-1.0 nvarguscamerasrc example.
For sensor-mode=1: The exposure values from [34000,33333333] actually change the exposure time. However, the range [33333334,358733008] does not produce a warning message and defaults the exposure time to some arbitrary default value which seems to be relatively dim.
Here are some extra questions:
If sensor-mode=1 is 60 fps, how is it that we can set the exposure time to 33,333,333ns (i.e. 1/30s), instead of 16,666,666ns
How can I have an exposure time over 1/30s. My application is very low light.
