Raw Bayer procesing with Argus
Hello.
I have this kind of pipe to implement:
Camera capture → Bayer processing with GPU → De-noise → Debayer → MPEG.
As I can see Argus with ISP can do capture, de-noise, debayer and mpeg easily (MPEG is optional actually).
I should somehow get into stream of Bayer data before ISP starts.
I can see that EGLStream as input stream from camera (Am I wright?).
So camera frames should be captured somehow, than processed with GPU and than the only option is to emulate this input camera stream to Argus and force ISP to post-process frames.
Am I wright? Is there another way to handle intermediate Bayer data before ISP processing?
Can I find ISP’s throughput timings and Megapixels estimates for it’s functions?
You can use v4l2 framework instead of argus/nvcamerasrc to get bayer data like v4l2-ctl
Thanks for reply, v4l2 is an option.
But we need to De-noise and Debayer after white balance and gamma correction in GPU.
So it would be good to use ISP instead of GPU NPP for example.
@a.v.pimenov
OK, then there’s no way for argus to get raw data from the pipeline in current software design.
