Nvidia TitanX
• DeepStream Version
5.1 latest Docker image (nvcr.io/nvidia/deepstream:5.1-21.02-triton)
• TensorRT Version
default one i guess 7.2.1
460.73.01
question
I have a strange problem. I set infer-raw-output-dir
parameter in the source file, however, network outputs are not saved in the given directory. Similarly, when i add that parameter to densenet example, it also didn’t save the results to given directory. On the contrary, faster-rcnn example works, i.e. it saves .bin files in the given directory.
I am running docker image with the command:
sudo docker run --gpus all -it --rm -v /path/to/other/mount_dir/video:/video -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream-5.1 nvcr.io/nvidia/deepstream:5.1-21.02-triton
And running the model with: deepstream-app -c source1_primary_mymodel.txt
Below I attached my corresponding files, help would be appreciated :)
source1_primary_mymodel.txt (2.1 KB) config_infer_mymodel.txt (849 Bytes) config.pbtxt (436 Bytes)
