Summary
Kernel NULL-pointer dereference inside nvidia_uvm triggered by the proprietary
driver’s own suspend path (nv_uvm_suspend → uvm_suspend → uvm_suspend_entry
→ nv_kthread_q_flush → _raw_q_flush+0x87) when the system enters S3/s2idle.
After the oops, nvidia-sleep.sh exits with IRQs disabled and preempt_count=1,
leaving kernel state corrupted. Subsequent threads that touch nvidia_uvm get
stuck in kernel space mid-do_exit() (state R, ignore SIGKILL), which in turn
prevents wait() reaping and produces immortal zombies for any process that
opened /dev/nvidia-uvm before the suspend.
Environment
| Distro | CachyOS (Arch-based, rolling) |
| Kernel | 7.0.2-2-cachyos (PREEMPT, x86_64) |
| NVIDIA driver | nvidia-580xx-dkms 580.159.03-2 (proprietary) |
| GPU | NVIDIA GeForce 940MX (GM108M, Maxwell) — PCI 01:00.0 |
| iGPU | Intel HD Graphics 520 (Skylake-U), i915 (primary display) |
| Hardware | Xiaomi Mi Notebook (Timi TM1613) |
| Firmware | Dell BIOS A05 2016-08-11 |
Setup is Optimus-style: the NVIDIA GPU has no display attached; the iGPU drives
all outputs. The dGPU is essentially unused in normal workloads — no CUDA,
no PRIME offload, no Vulkan apps targeting it. The crash happens purely because
the driver is loaded and registers a suspend hook; the GPU itself has done
no meaningful work prior to the oops.
Module / power-management config (already correct)
/usr/lib/modprobe.d/nvidia-sleep.conf:
options nvidia NVreg_PreserveVideoMemoryAllocations=1 NVreg_TemporaryFilePath=/var/tmp
/etc/modprobe.d/nvidia.conf:
options nvidia-drm modeset=1
options nvidia NVreg_UsePageAttributeTable=1 NVreg_InitializeSystemMemoryAllocations=0
nvidia-suspend.service, nvidia-resume.service, nvidia-hibernate.service
are all enabled.
Trace
Full extract attached as oops.log. Key frames:
BUG: kernel NULL pointer dereference, address: 0000000000000000
#PF: supervisor read access in kernel mode
PGD 0 P4D 0
Oops: Oops: 0000 [#1] SMP PTI
CPU: 3 UID: 0 PID: 322138 Comm: nvidia-sleep.sh
Tainted: P S OE 7.0.2-2-cachyos #1 PREEMPT
RIP: 0010:_raw_q_flush+0x87/0x110 [nvidia_uvm]
Code: ... 48 39 1e ... <-- cmp %rbx,(%rsi) with RSI=0
RSI: 0000000000000000 RDI: ffffd393cde20318
Call Trace:
nv_kthread_q_flush+0x18/0x70 [nvidia_uvm]
uvm_suspend+0x17b/0x1a0 [nvidia_uvm]
uvm_suspend_entry+0xb6/0xf0 [nvidia_uvm]
nv_uvm_suspend+0x32/0x50 [nvidia]
nv_set_system_power_state+0x329/0x510 [nvidia]
nv_procfs_write_suspend+0x129/0x160 [nvidia]
proc_reg_write+0x68/0xb0
__x64_sys_write+0x3f6/0x480
do_syscall_64+0x6d/0xa90
entry_SYSCALL_64_after_hwframe+0x76/0x7e
note: nvidia-sleep.sh[322138] exited with irqs disabled
note: nvidia-sleep.sh[322138] exited with preempt_count 1
Right after the oops the kernel still attempts the suspend cycle and logs:
NVRM: GPU 0000:01:00.0: PreserveVideoMemoryAllocations module parameter is set.
System Power Management attempted without driver procfs suspend interface.
Please refer to the 'Configuring Power Management Support' section in the driver README.
nvidia 0000:01:00.0: PM: pci_pm_suspend(): nv_pmops_suspend [nvidia] returns -5
nvidia 0000:01:00.0: PM: failed to suspend async: error -5
(NB: nvidia-suspend.service had successfully written to the procfs interface
just moments earlier — the message appears because the service was killed by
the oops mid-write, so subsequent retry tries without the procfs handshake.)
Reproduction
100% reproducible on this machine when:
- NVIDIA driver 580.159.03 is loaded with
NVreg_PreserveVideoMemoryAllocations=1. - An application that links FFmpeg/libmpv (compiled with
--enable-nvdec --enable-nvenc --enable-cuda-llvm) is launched — in my case Stremio,
which useslibmpv.so.2+libavcodec.so.62from system FFmpeg. - System is suspended (
systemctl suspend).
Triage details
I initially suspected QtWebEngine (Stremio embeds it). Triage rules it out:
- Pre-launch baseline:
nvidia_uvmblacklisted and not loaded
(lsmod | grep nvidia_uvm→ empty). - After running
stremio(no video played, just opening the UI):
nvidia_uvmis loaded withused by 2. - Same result with
QTWEBENGINE_CHROMIUM_FLAGS="--disable-gpu" stremio. - Inspecting
/proc/<stremio-pid>/mapsafter launch shows
libcuda.so.580.159.03mapped, and/proc/<stremio-pid>/fd/lists open
handles to/dev/nvidiactl,/dev/nvidia-uvm,/dev/nvidia0. node(the Stremio server) does not map any NVIDIA libraries.ldd /opt/stremio/stremio→libmpv.so.2,libavcodec.so.62,
libavformat.so.62,libavutil.so.60,libavdevice.so.62— system FFmpeg
built--enable-nvdec --enable-nvenc --enable-cuda-llvm. FFmpeg/libmpv lazy-
loadslibcuda.soat init for capability probing, which is enough to load
nvidia_uvmand stage the kernel for the later suspend oops.
So the “Stremio-only” trigger generalizes to: any app that links libmpv or
libavcodec from a CUDA-enabled FFmpeg build. The kernel oops itself is
independent of how nvidia_uvm got loaded — it just needs nvidia_uvm to be
loaded when the suspend hook runs.
Workaround that confirms the trigger
Blacklisting nvidia_uvm (plus overriding
/usr/lib/modules-load.d/nvidia-580xx-utils.conf with an empty file in
/etc/modules-load.d/) prevents the module from being loaded at boot or by
FFmpeg’s dlopen. With this in place, the same Stremio session followed by
systemctl suspend completes cleanly — no oops, no zombies, system resumes
normally.
When the bug does hit, the side effects are: oops in _raw_q_flush,
nvidia-suspend.service ends in failed (signal=KILL), nvidia-resume.service
then sticks in activating (start) indefinitely (in my case 10+ hours).
Aftermath
/sys/module/nvidia/parameters/disappears (module in undefined state).- Any thread that dispatches into
nvidia_uvmlater can get stuck in kernel
space during exit. Example: aThreadPoolForegworker thread of Stremio
(PID 320117) is in stateRwithwchan: 0, has already released
mm/fd/exe(so it’s mid-do_exit()), but never finishes —SigPnd: 0,
nonvoluntary_ctxt_switches: 312717, ignores SIGKILL. Its parent (also a
zombie) cannot be reaped bysystemd --user, leaving immortal zombies until
reboot. - System remains usable for non-GPU workloads but cannot suspend cleanly and
any process touching the NVIDIA stack risks getting stuck.
Suspected cause
_raw_q_flush+0x87 decodes to cmp %rbx,(%rsi) with RSI=0, i.e. the queue
flush walks a list whose head/next pointer is NULL. Likely causes:
- The internal
nv_kthread_qwas never initialized for this UVM context, or - It was already torn down (e.g. by a prior failed init / partial suspend), but
uvm_suspendstill callsnv_kthread_q_flushon it.
The Maxwell (GM10x) family is in deprecated/legacy support in the 580 branch;
this codepath may not be exercised regularly upstream.
Consistent with what the triage shows: an FFmpeg-based dlopen of
libcuda.so performs a CUDA capability probe that briefly opens
/dev/nvidia-uvm (causing nvidia_uvm to load) and then closes it. The
context teardown evidently leaves a partially-initialised nv_kthread_q
behind, which the later global uvm_suspend traverses and dereferences a
NULL list pointer in.
Workaround that does not work
The standard advice (enable nvidia-{suspend,resume,hibernate}.service and set
NVreg_PreserveVideoMemoryAllocations=1 + NVreg_TemporaryFilePath) is
already in place on this system — and it’s exactly the combination that
triggers the oops.
Workarounds that may help
- Unsetting
NVreg_PreserveVideoMemoryAllocations(drop video memory across
suspend) — not yet tested, would avoid theuvm_suspendpath entirely. - Blacklisting
nvidia_uvmif CUDA is not needed. - For headless-NVIDIA Optimus laptops where the iGPU drives the display:
blacklisting all NVIDIA modules (and relying oni915only).
Note: blacklisting nvidia_uvm requires two changes
The nvidia-580xx-utils package ships
/usr/lib/modules-load.d/nvidia-580xx-utils.conf which contains
nvidia-uvm — i.e. it asks systemd-modules-load.service to load
nvidia_uvm at boot, explicitly. A blacklist nvidia_uvm line in
/etc/modprobe.d/ does not prevent this, because blacklist only blocks
implicit / autoload requests, not explicit ones from modules-load.d.
To actually keep nvidia_uvm unloaded, both of these are needed:
# /etc/modprobe.d/blacklist-nvidia-uvm.conf
# /etc/modules-load.d/nvidia-580xx-utils.conf
# (empty — overrides /usr/lib/modules-load.d/nvidia-580xx-utils.conf)
It would be friendlier if nvidia-uvm were loaded lazily (on first
/dev/nvidia-uvm open) instead of being force-loaded at boot, especially on
Optimus systems where the dGPU is rarely used and the only effect of having
nvidia_uvm loaded is risk exposure to bugs like this one.
Attached
oops.log— kernel ring buffer covering the oops + suspend cycle. -
full-boot.log— fulloops.log (13.2 KB)
nvidia-bug-report.log.gz (832.3 KB)
full-boot.log (298.0 KB)
journalctl -k -bof the affected boot. -
nvidia-bug-report.log.gz— generated withsudo nvidia-bug-report.sh
on the same machine after a clean reboot.
