Hi NV_Team,
We have implement a RAW12 sensor, v4l2 can capture frames but nvargus can not open this sensor.
JetPack6.0
byd@ubuntu:~$ v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'RG12' (12-bit Bayer RGRG/GBGB)
Size: Discrete 1920x1300
Interval: Discrete 0.033s (30.000 fps)
byd@ubuntu:~$ v4l2-ctl --list-devicesNVIDIA Tegra Video Input Device (platform:tegra-camrtc-ca):/dev/media0
vi-output, isx031 3-003d (platform:tegra-capture-vi:0):
/dev/video0
/dev/video1
V4L2 Commands:
byd@ubuntu:~$ v4l2-ctl -V --set-fmt-video width=1920,height=1300,pixelformat=RG12 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=100 -d /dev/video1
Format Video Capture:
Width/Height : 1920/1300
Pixel Format : 'RG12' (12-bit Bayer RGRG/GBGB)
Field : None
Bytes per Line : 3840
Size Image : 4992000
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Full Range)
Flags :
<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< 30.00 fps
NVARGUS Commands:
byd@ubuntu:~$ gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1300, framerate=30/1' ! nvvidconv ! 'video/x-raw, format=(string)I420' ! xvimagesink -e
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 1920 x 1300 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 251.188705; Exposure Range min 30000, max 660000000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 0
Output Stream W = 1920 H = 1300
seconds to Run = 0
Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: CANCELLED
Additional debug info:
Argus Error Status
nvbuf_utils: dmabuf_fd -1 mapped entry NOT found
Execution ended after 0:00:02.712645375
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadExecute:732 Setting pipeline to NULL ...
NvBufSurfaceFromFd Failed.
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, threadFunction:243 (propagating)
GST_ARGUS: Cleaning up
Freeing pipeline ...
=== NVIDIA Libargus Camera Service (0.99.33)=== Listening for connections...=== gst-launch-1.0[8193]: Connection established (FFFF9530B840)OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module0
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module2
OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module3
NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
NvPclHwGetModuleList: No module data found
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
---- imager: No override file found. ----
(NvCamV4l2) Error ModuleNotPresent: V4L2Device not available (in /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function findDevice(), line 256)
(NvCamV4l2) Error ModuleNotPresent: (propagating from /dvs/git/dirty/git-master_linux/camera/utils/nvcamv4l2/v4l2_device.cpp, function initialize(), line 60)
(NvOdmDevice) Error ModuleNotPresent: (propagating from dvs/git/dirty/git-master_linux/camera-partner/imager/src/devices/V4L2SensorViCsi.cpp, function initialize(), line 111)
NvPclDriverInitializeData: Unable to initialize driver v4l2_sensor
NvPclInitializeDrivers: error: Failed to init camera sub module v4l2_sensor
NvPclStartPlatformDrivers: Failed to start module drivers
NvPclStateControllerOpen: Failed ImagerGUID 0. (error 0xA000E)
NvPclOpen: PCL Open Failed. Error: 0xf
SCF: Error BadParameter: Sensor could not be opened. (in src/services/capture/CaptureServiceDeviceSensor.cpp, function getSourceFromGuid(), line 725)
SCF: Error BadParameter: (propagating from src/services/capture/CaptureService.cpp, function addSourceByGuid(), line 453)
SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function addSourceByIndex(), line 347)
SCF: Error BadParameter: (propagating from src/api/CameraDriver.cpp, function getSource(), line 519)
LSC: LSC surface is not based on full res!
NvPclStateControllerOpen: Failed ImagerGUID 1. (error 0xA000E)
=== gst-launch-1.0[8193]: CameraProvider initialized (0xffff90a37c70)LSC: LSC surface is not based on full res!
SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 4, capture sequence ID = 0 draining session frameStart events 3
(in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 527)
SCF: Error InvalidState: Sensor GUID 4 is in error state. Skipping requests, capture sequence ID = 1 continue draining session frameStart events 2
(in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameStart(), line 541)
SCF: Error InvalidState: Sensor GUID 4 is in error state. Skipping requests, capture sequence ID = 2 continue draining session frameStart events 1
PowerServiceCore:handleRequests: timePassed = 2650
SCF: Error InvalidState: Sensor 4 already in same state
(in src/services/capture/CaptureServiceDeviceSensor.cpp, function setErrorState(), line 100)
SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 4, capture sequence ID = 0 draining session frameEnd events 3
(in src/services/capture/FusaCaptureViCsiHw.cpp, function waitCsiFrameEnd(), line 644)
SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 4, capture sequence ID = 1 draining session frameEnd events 2
SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 4, capture sequence ID = 2 draining session frameEnd events 1
SCF: Error Timeout: Sending critical error event for Session 4
(in src/api/Session.cpp, function sendErrorEvent(), line 1039)
SCF: Error InvalidState: Sensor GUID 4 is in error state. Skipping requests, capture sequence ID = 3 continue draining session frameStart events 1
SCF: Error InvalidState: Timeout!! Skipping requests on sensor GUID 4, capture sequence ID = 3 draining session frameEnd events 1
SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/FusaCaptureViCsiHw.cpp, function startCaptureInternal(), line 875)
SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/CaptureRecord.cpp, function doCSItoMemCapture(), line 536)
SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/CaptureRecord.cpp, function issueCapture(), line 483)
SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/CaptureServiceDevice.cpp, function issueCaptures(), line 1565)
SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/CaptureServiceDevice.cpp, function issueCaptures(), line 1394)
SCF: Error ResourceAlreadyInUse: (propagating from src/common/Utils.cpp, function workerThread(), line 114)
SCF: Error ResourceAlreadyInUse: Worker thread CaptureScheduler frameStart failed (in src/common/Utils.cpp, function workerThread(), line 133)
SCF: Error Timeout: (propagating from src/api/Buffer.cpp, function waitForUnlock(), line 644)
SCF: Error Timeout: (propagating from src/components/CaptureContainerImpl.cpp, function returnBuffer(), line 430)
SCF: Error OverFlow: (propagating from src/services/capture/CaptureServiceDevice.cpp, function checkCaptureComplete(), line 1486)
SCF: Error OverFlow: (propagating from src/common/Utils.cpp, function workerThread(), line 114)
SCF: Error OverFlow: Worker thread CaptureScheduler checkFramePending failed (in src/common/Utils.cpp, function workerThread(), line 133)
