I’ve just installed a fresh release of Fedora Core 10 for x86_64.
I’ve installed last cuda driver and sdk.
When I try to launch dnetc, it downloads datas but, just after that,
it tells me that an error occured and that the device is already in use…
It tells CUDA: ERROR too.
I’ve tried it into “init 3” mode and it’s the same way.
Drivers are for fedora 9 but the ones for version 10 are not available, afaik.
Has anyone tried to run dnetc for x86_64 under fedora 10 ?
[Dec 04 12:41:54 UTC] Automatic processor detection found 1 processor.
[Dec 04 12:41:54 UTC] Connected to euro.v29.distributed.net:2064…
[Dec 04 11:43:30 UTC] The keyserver says: “Moo from the new and improved
haystack.ivo.nu”
[Dec 04 11:43:30 UTC] Retrieved project state data from server. (cached)
[Dec 04 11:43:34 UTC] RC5-72: Retrieved stats unit 24 of 24 (100.00%)
[Dec 04 11:43:34 UTC] Connection closed.
[Dec 04 11:43:34 UTC] Automatic processor type detection found
a GeForce 9800 GTX/9800 GTX+ processor.
[Dec 04 11:43:34 UTC] RC5-72: Running micro-bench to select fastest core…
RC5 cuda: CUDA CORE ERROR: setting the device when a process is active is not allowed
RC5 cuda: error_exit
RC5 cuda: ERROR: no error
[Dec 04 11:43:34 UTC] RC5-72: using core #0 (CUDA 1-pipe).
[Dec 04 11:43:34 UTC] RC5-72: Loaded CB:E7D270BC:00000000:1*2^32
[Dec 04 11:43:34 UTC] RC5-72: 23 packets (23.00 stats units) remain in
(memory-in)
[Dec 04 11:43:34 UTC] RC5-72: 0 packets are in (memory-out)
[Dec 04 11:43:34 UTC] 1 cruncher has been started.
[Dec 04 11:43:34 UTC] *** This BETA release expires in 19.15:43:35.00. ***
I run fedora 10 : 2.6.27.5-117.fc10.x86_64 #1 SMP Tue Nov 18 11:58:53 EST 2008 x86_64 x86_64 x86_64 GNU/Linux
Well, finally, after all elements,I installed “Cuda Toolkit for fedora 8” and it runs.
I get [387,143,260 keys/s] (max) on a 9800gtx+, driver 180.06 for linux64 under Fedora 10 x86_64
on an A64 x2 4200+ with 2GB ram.
It frequently checks buffers.
PC under xp gives approx 20 Mkeys, PS3 under Yellow Dog 6 gives approx 180 and here,
it’s rating near 350 Mkeys.
