RCE Traces does not have vi_frame_end
Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
I am debugging a YUV format camera, max96712 MIPI output is available, but RCE Traces only have
vi_frame_begin does not have vi_frame_end, It’s OK for me to use TPG,So I want to know what to do next?
Are there any other debugging methods?
Error String
run nvsipl_camera
Queue timeout
Queue timeout
Queue timeout
Queue timeout
Logs
tracer: nop
entries-in-buffer/entries-written: 2292/2292 #P:12
_-------=> irqs-off
/ _------=> need-resched
| / _-----=> need-resched-lazy
|| / _----=> hardirq/softirq
||| / _—=> preempt-depth
|||| / _–=> preempt-lazy-depth
||||| / _-=> migrate-disable
|||||| / delay
TASK-PID CPU# ||||||| TIMESTAMP FUNCTION
 kworker/4:0-47      [004] .......   821.671681: rtcpu_dbg_enter: tstamp:25795374034, data:4
 kworker/4:0-47      [004] .......   821.671685: rtcpu_dbg_set_loglevel: tstamp:25795374214 old:3 new:3
 kworker/4:0-47      [004] .......   821.671685: rtcpu_dbg_exit: tstamp:25795374397
 kworker/4:0-47      [004] .......   893.923680: rtcpu_vinotify_event: tstamp:28054128667 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:897727609920 data:0x559d580010000000
 kworker/4:0-47      [004] .......   893.923682: rtcpu_vinotify_event: tstamp:28054128898 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:897727616992 data:0x0000000031000001
 kworker/4:0-47      [004] .......   893.923682: rtcpu_vinotify_event: tstamp:28054129148 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:897727620352 data:0x0000000007020001
 kworker/4:0-47      [004] .......   893.923683: rtcpu_vinotify_event: tstamp:28054129364 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:897727714944 data:0x559d550010000000
 kworker/4:0-47      [004] .......   893.923683: rtcpu_vinotify_event: tstamp:28054129632 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:897727722144 data:0x0000000031000002
 kworker/4:0-47      [004] .......   894.939684: rtcpu_nvcsi_intr: tstamp:28085287690 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x01c00000
 kworker/4:0-47      [004] .......   894.939685: rtcpu_nvcsi_intr: tstamp:28085287690 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00c00000
 kworker/4:0-47      [004] .......   894.939687: vi_frame_begin: tstamp:28085464870 cch:0 syncpt_id:281 syncpt_thresh:5 class_id:48
 kworker/4:0-47      [004] .......   894.939688: rtcpu_vinotify_event: tstamp:28085577579 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:898734248512 data:0x0000000000000010
 kworker/4:0-47      [004] .......   894.939688: rtcpu_vinotify_event: tstamp:28085577846 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:898734248544 data:0x0000000800000000
 kworker/4:0-47      [004] .......   894.939688: rtcpu_vinotify_event: tstamp:28085578068 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:898734875840 data:0x0000000000000001
 kworker/4:0-47      [004] .......   894.939688: rtcpu_vinotify_event: tstamp:28085578313 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:898734877376 data:0x0000000008020001
 kworker/4:0-47      [004] .......   894.939689: rtcpu_vinotify_event: tstamp:28085578528 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:898734878400 data:0x0000000000000100
 kworker/4:0-47      [004] .......   894.939689: rtcpu_vinotify_event: tstamp:28085578765 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:898734890208 data:0x0000000001020001
 kworker/4:0-47      [004] .......   894.939689: rtcpu_vinotify_event: tstamp:28085908539 cch:0 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:0 vi_tstamp:898746483296 data:0x0000000000000000
 kworker/4:0-47      [004] .......   894.939689: rtcpu_vinotify_event: tstamp:28086169442 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:898757362208 data:0x0000000000000020
 kworker/4:0-47      [004] .......   894.939690: rtcpu_vinotify_event: tstamp:28086169669 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:898757362208 data:0x0438200001000000
 kworker/4:0-47      [004] .......   894.939690: rtcpu_vinotify_event: tstamp:28086169919 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:898757362240 data:0x0000000800000000
 kworker/4:0-47      [004] .......   894.939690: rtcpu_vinotify_event: tstamp:28086170137 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:898757376128 data:0x0000000007020002
 kworker/4:0-47      [004] .......   894.999676: rtcpu_vinotify_event: tstamp:28086471317 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:898757399456 data:0x559d580010000000
 kworker/4:0-47      [004] .......   894.999677: rtcpu_vinotify_event: tstamp:28086471540 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:898757405920 data:0x0000000031000003
 kworker/4:0-47      [004] .......   894.999677: vi_frame_begin: tstamp:28086506570 cch:0 syncpt_id:281 syncpt_thresh:10 class_id:48
 kworker/4:0-47      [004] .......   894.999678: rtcpu_vinotify_event: tstamp:28086802304 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:898767582912 data:0x0000000000000010
 kworker/4:0-47      [004] .......   894.999678: rtcpu_vinotify_event: tstamp:28086802532 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:898767582944 data:0x0000000800000000
 kworker/4:0-47      [004] .......   894.999678: rtcpu_vinotify_event: tstamp:28086802784 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:898768210240 data:0x0000000000000001
 kworker/4:0-47      [004] .......   894.999678: rtcpu_vinotify_event: tstamp:28086803004 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:898768211776 data:0x0000000008020002
 kworker/4:0-47      [004] .......   894.999678: rtcpu_vinotify_event: tstamp:28086803249 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:898768212800 data:0x0000000000000100
 kworker/4:0-47      [004] .......   894.999679: rtcpu_vinotify_event: tstamp:28086803466 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:898768223424 data:0x0000000001020002
 kworker/4:0-47      [004] .......   894.999679: rtcpu_vinotify_event: tstamp:28087133445 cch:0 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:0 vi_tstamp:898779817728 data:0x0000000000000000
 kworker/4:0-47      [004] .......   894.999679: rtcpu_vinotify_event: tstamp:28087464407 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:898790696576 data:0x0000000000000020
 kworker/4:0-47      [004] .......   894.999679: rtcpu_vinotify_event: tstamp:28087464652 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:898790696608 data:0x0438200001000000
 kworker/4:0-47      [004] .......   894.999679: rtcpu_vinotify_event: tstamp:28087464878 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:898790696608 data:0x0000000800000000
 kworker/4:0-47      [004] .......   894.999679: rtcpu_vinotify_event: tstamp:28087465119 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:898790710528 data:0x0000000007020003
 kworker/4:0-47      [004] .......   894.999680: rtcpu_vinotify_event: tstamp:28087465338 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:898790724384 data:0x559d550010000000
 kworker/4:0-47      [004] .......   894.999680: rtcpu_vinotify_event: tstamp:28087465581 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:898790732032 data:0x0000000031000004
 kworker/4:0-47      [004] .......   894.999680: rtcpu_vinotify_event: tstamp:28087530171 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:898800917312 data:0x0000000000000010
 kworker/4:0-47      [004] .......   894.999680: vi_frame_begin: tstamp:28087548271 cch:0 syncpt_id:281 syncpt_thresh:15 class_id:48
 kworker/4:0-47      [004] .......   894.999680: rtcpu_vinotify_event: tstamp:28087828650 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:898800917344 data:0x0000000800000000
 kworker/4:0-47      [004] .......   894.999680: rtcpu_vinotify_event: tstamp:28087828878 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:898801544672 data:0x0000000000000001
 kworker/4:0-47      [004] .......   894.999681: rtcpu_vinotify_event: tstamp:28087829127 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:898801546176 data:0x0000000008020003
 kworker/4:0-47      [004] .......   894.999681: rtcpu_vinotify_event: tstamp:28087829345 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:898801547168 data:0x0000000000000100
 kworker/4:0-47      [004] .......   894.999681: rtcpu_vinotify_event: tstamp:28087829590 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:898801557792 data:0x0000000001020003
 kworker/4:0-47      [004] .......   894.999681: rtcpu_vinotify_event: tstamp:28088159647 cch:0 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:0 vi_tstamp:898813152128 data:0x0000000000000000
 kworker/4:0-47      [004] .......   895.055678: rtcpu_vinotify_event: tstamp:28088490727 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:898824030976 data:0x0000000000000020
 kworker/4:0-47      [004] .......   895.055679: rtcpu_vinotify_event: tstamp:28088490949 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:898824030976 data:0x0438200001000000
 kworker/4:0-47      [004] .......   895.055679: rtcpu_vinotify_event: tstamp:28088491201 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:898824031008 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.055679: rtcpu_vinotify_event: tstamp:28088491421 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:898824044896 data:0x0000000007020004
 kworker/4:0-47      [004] .......   895.055679: rtcpu_vinotify_event: tstamp:28088491662 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:898824055872 data:0x559d580010000000
 kworker/4:0-47      [004] .......   895.055680: rtcpu_vinotify_event: tstamp:28088491883 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:898824063008 data:0x0000000031000005
 kworker/4:0-47      [004] .......   895.055680: vi_frame_begin: tstamp:28088589971 cch:0 syncpt_id:281 syncpt_thresh:20 class_id:48
 kworker/4:0-47      [004] .......   895.055680: rtcpu_vinotify_event: tstamp:28088595766 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:898834251712 data:0x0000000000000010
 kworker/4:0-47      [004] .......   895.055680: rtcpu_vinotify_event: tstamp:28088595991 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:898834251712 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.055681: rtcpu_vinotify_event: tstamp:28088596242 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:898834879072 data:0x0000000000000001
 kworker/4:0-47      [004] .......   895.055681: rtcpu_vinotify_event: tstamp:28088596460 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:898834880576 data:0x0000000008020004
 kworker/4:0-47      [004] .......   895.055681: rtcpu_vinotify_event: tstamp:28088921033 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:898834881568 data:0x0000000000000100
 kworker/4:0-47      [004] .......   895.055681: rtcpu_vinotify_event: tstamp:28088921259 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:898834894496 data:0x0000000001020004
 kworker/4:0-47      [004] .......   895.055682: rtcpu_vinotify_event: tstamp:28089252016 cch:0 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:0 vi_tstamp:898846486496 data:0x0000000000000000
 kworker/4:0-47      [004] .......   895.055682: rtcpu_vinotify_event: tstamp:28089583118 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:898857365376 data:0x0000000000000020
 kworker/4:0-47      [004] .......   895.055682: rtcpu_vinotify_event: tstamp:28089583358 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:898857365376 data:0x0438200001000000
 kworker/4:0-47      [004] .......   895.055682: rtcpu_vinotify_event: tstamp:28089583577 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:898857365376 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.055682: rtcpu_vinotify_event: tstamp:28089583821 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:898857379264 data:0x0000000007020005
 kworker/4:0-47      [004] .......   895.055683: rtcpu_vinotify_event: tstamp:28089584039 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:898857392512 data:0x559d550010000000
 kworker/4:0-47      [004] .......   895.055683: rtcpu_vinotify_event: tstamp:28089584279 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:898857399680 data:0x0000000031000006
 kworker/4:0-47      [004] .......   895.055683: vi_frame_begin: tstamp:28089631670 cch:0 syncpt_id:281 syncpt_thresh:25 class_id:48
 kworker/4:0-47      [004] .......   895.055683: rtcpu_vinotify_event: tstamp:28089914105 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:898867586080 data:0x0000000000000010
 kworker/4:0-47      [004] .......   895.055683: rtcpu_vinotify_event: tstamp:28089914362 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:898867586112 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.055683: rtcpu_vinotify_event: tstamp:28089914586 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:898868213440 data:0x0000000000000001
 kworker/4:0-47      [004] .......   895.055685: rtcpu_vinotify_event: tstamp:28089914830 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:898868214976 data:0x0000000008020005
 kworker/4:0-47      [004] .......   895.055685: rtcpu_vinotify_event: tstamp:28089915047 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:898868216000 data:0x0000000000000100
 kworker/4:0-47      [004] .......   895.055685: rtcpu_vinotify_event: tstamp:28089915286 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:898868226592 data:0x0000000001020005
 kworker/4:0-47      [004] .......   895.055686: rtcpu_vinotify_event: tstamp:28089995866 cch:0 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:0 vi_tstamp:898879820896 data:0x0000000000000000
 kworker/4:0-47      [004] .......   895.111675: rtcpu_vinotify_event: tstamp:28090344460 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:898890699776 data:0x0000000000000020
 kworker/4:0-47      [004] .......   895.111675: rtcpu_vinotify_event: tstamp:28090344682 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:898890699776 data:0x0438200001000000
 kworker/4:0-47      [004] .......   895.111676: rtcpu_vinotify_event: tstamp:28090344931 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:898890699776 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.111676: rtcpu_vinotify_event: tstamp:28090345153 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:898890713696 data:0x0000000007020006
 kworker/4:0-47      [004] .......   895.111676: rtcpu_vinotify_event: tstamp:28090345395 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:898890728160 data:0x559d580010000000
 kworker/4:0-47      [004] .......   895.111676: rtcpu_vinotify_event: tstamp:28090345611 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:898890735328 data:0x0000000031000007
 kworker/4:0-47      [004] .......   895.111676: vi_frame_begin: tstamp:28090673370 cch:0 syncpt_id:281 syncpt_thresh:30 class_id:48
 kworker/4:0-47      [004] .......   895.111677: rtcpu_vinotify_event: tstamp:28090679127 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:898900920480 data:0x0000000000000010
 kworker/4:0-47      [004] .......   895.111677: rtcpu_vinotify_event: tstamp:28090679350 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:898900920512 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.111677: rtcpu_vinotify_event: tstamp:28090679598 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:898901547840 data:0x0000000000000001
 kworker/4:0-47      [004] .......   895.111678: rtcpu_vinotify_event: tstamp:28090679813 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:898901549376 data:0x0000000008020006
 kworker/4:0-47      [004] .......   895.111678: rtcpu_vinotify_event: tstamp:28090680054 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:898901550368 data:0x0000000000000100
 kworker/4:0-47      [004] .......   895.111678: rtcpu_vinotify_event: tstamp:28090680270 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:898901560992 data:0x0000000001020006
 kworker/4:0-47      [004] .......   895.111678: rtcpu_vinotify_event: tstamp:28091337744 cch:0 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:0 vi_tstamp:898913155296 data:0x0000000000000000
 kworker/4:0-47      [004] .......   895.111679: rtcpu_vinotify_event: tstamp:28091377872 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:898924034176 data:0x0000000000000020
 kworker/4:0-47      [004] .......   895.111679: rtcpu_vinotify_event: tstamp:28091378113 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:898924034176 data:0x0438200001000000
 kworker/4:0-47      [004] .......   895.111679: rtcpu_vinotify_event: tstamp:28091378339 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:898924034176 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.111679: rtcpu_vinotify_event: tstamp:28091701714 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:898924049376 data:0x0000000007020007
 kworker/4:0-47      [004] .......   895.111679: rtcpu_vinotify_event: tstamp:28091701936 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:898924070048 data:0x559d550010000000
 kworker/4:0-47      [004] .......   895.111680: rtcpu_vinotify_event: tstamp:28091702204 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:898924077696 data:0x0000000031000008
 kworker/4:0-47      [004] .......   895.111680: rtcpu_vinotify_event: tstamp:28091702422 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:898934254880 data:0x0000000000000010
 kworker/4:0-47      [004] .......   895.111680: rtcpu_vinotify_event: tstamp:28091702671 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:898934254880 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.111680: vi_frame_begin: tstamp:28091715070 cch:0 syncpt_id:281 syncpt_thresh:35 class_id:48
 kworker/4:0-47      [004] .......   895.167676: rtcpu_vinotify_event: tstamp:28092032893 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:898934882240 data:0x0000000000000001
 kworker/4:0-47      [004] .......   895.167677: rtcpu_vinotify_event: tstamp:28092033152 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:898934883744 data:0x0000000008020007
 kworker/4:0-47      [004] .......   895.167677: rtcpu_vinotify_event: tstamp:28092033384 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:898934884768 data:0x0000000000000100
 kworker/4:0-47      [004] .......   895.167677: rtcpu_vinotify_event: tstamp:28092033631 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:898934895360 data:0x0000000001020007
 kworker/4:0-47      [004] .......   895.167678: rtcpu_vinotify_event: tstamp:28092363848 cch:0 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:0 vi_tstamp:898946489664 data:0x0000000000000000
 kworker/4:0-47      [004] .......   895.167678: rtcpu_vinotify_event: tstamp:28092420286 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:898957368576 data:0x0000000000000020
 kworker/4:0-47      [004] .......   895.167678: rtcpu_vinotify_event: tstamp:28092420513 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:898957368576 data:0x0438200001000000
 kworker/4:0-47      [004] .......   895.167678: rtcpu_vinotify_event: tstamp:28092420768 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:898957368576 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.167679: rtcpu_vinotify_event: tstamp:28092420991 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:898957382464 data:0x0000000007020008
 kworker/4:0-47      [004] .......   895.167679: rtcpu_vinotify_event: tstamp:28092421238 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:898957396160 data:0x559d580010000000
 kworker/4:0-47      [004] .......   895.167679: rtcpu_vinotify_event: tstamp:28092421456 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:898957403296 data:0x0000000031000009
 kworker/4:0-47      [004] .......   895.167679: vi_frame_begin: tstamp:28092756769 cch:0 syncpt_id:281 syncpt_thresh:40 class_id:48
 kworker/4:0-47      [004] .......   895.167680: rtcpu_vinotify_event: tstamp:28092762731 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:898967589280 data:0x0000000000000010
 kworker/4:0-47      [004] .......   895.167680: rtcpu_vinotify_event: tstamp:28092762960 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:898967589280 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.167680: rtcpu_vinotify_event: tstamp:28092763210 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:898968216608 data:0x0000000000000001
 kworker/4:0-47      [004] .......   895.167680: rtcpu_vinotify_event: tstamp:28092763428 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:898968218144 data:0x0000000008020008
 kworker/4:0-47      [004] .......   895.167680: rtcpu_vinotify_event: tstamp:28092763672 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:898968219168 data:0x0000000000000100
 kworker/4:0-47      [004] .......   895.167680: rtcpu_vinotify_event: tstamp:28092763889 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:898968229760 data:0x0000000001020008
 kworker/4:0-47      [004] .......   895.167681: rtcpu_vinotify_event: tstamp:28093423235 cch:0 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:0 vi_tstamp:898979824096 data:0x0000000000000000
 kworker/4:0-47      [004] .......   895.227674: rtcpu_vinotify_event: tstamp:28093754201 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:898990702976 data:0x0000000000000020
 kworker/4:0-47      [004] .......   895.227675: rtcpu_vinotify_event: tstamp:28093754447 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:898990702976 data:0x0438200001000000
 kworker/4:0-47      [004] .......   895.227675: rtcpu_vinotify_event: tstamp:28093754674 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:898990702976 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.227675: rtcpu_vinotify_event: tstamp:28093754921 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:898990716864 data:0x0000000007020009
 kworker/4:0-47      [004] .......   895.227675: rtcpu_vinotify_event: tstamp:28093755144 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:898990728320 data:0x559d550010000000
 kworker/4:0-47      [004] .......   895.227676: rtcpu_vinotify_event: tstamp:28093755388 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:898990735488 data:0x000000003100000a
 kworker/4:0-47      [004] .......   895.227676: vi_frame_begin: tstamp:28093798469 cch:0 syncpt_id:281 syncpt_thresh:45 class_id:48
 kworker/4:0-47      [004] .......   895.227676: rtcpu_vinotify_event: tstamp:28093804258 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:899000923680 data:0x0000000000000010
 kworker/4:0-47      [004] .......   895.227676: rtcpu_vinotify_event: tstamp:28093804512 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:899000923680 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.227677: rtcpu_vinotify_event: tstamp:28093804735 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:899001551008 data:0x0000000000000001
 kworker/4:0-47      [004] .......   895.227677: rtcpu_vinotify_event: tstamp:28094118515 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899001553856 data:0x0000000008020009
 kworker/4:0-47      [004] .......   895.227677: rtcpu_vinotify_event: tstamp:28094118745 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:899001553536 data:0x0000000000000100
 kworker/4:0-47      [004] .......   895.227677: rtcpu_vinotify_event: tstamp:28094118996 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899001566496 data:0x0000000001020009
 kworker/4:0-47      [004] .......   895.227677: rtcpu_vinotify_event: tstamp:28094449402 cch:0 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:0 vi_tstamp:899013158496 data:0x0000000000000000
 kworker/4:0-47      [004] .......   895.227678: rtcpu_vinotify_event: tstamp:28094780512 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:899024037376 data:0x0000000000000020
 kworker/4:0-47      [004] .......   895.227678: rtcpu_vinotify_event: tstamp:28094780736 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:899024037376 data:0x0438200001000000
 kworker/4:0-47      [004] .......   895.227678: rtcpu_vinotify_event: tstamp:28094780989 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:899024037376 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.227678: rtcpu_vinotify_event: tstamp:28094781217 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899024051264 data:0x000000000702000a
 kworker/4:0-47      [004] .......   895.227678: rtcpu_vinotify_event: tstamp:28094781465 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899024064704 data:0x559d580010000000
 kworker/4:0-47      [004] .......   895.227679: rtcpu_vinotify_event: tstamp:28094781680 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899024071872 data:0x000000003100000b
 kworker/4:0-47      [004] .......   895.227679: vi_frame_begin: tstamp:28094840169 cch:0 syncpt_id:281 syncpt_thresh:50 class_id:48
 kworker/4:0-47      [004] .......   895.227679: rtcpu_vinotify_event: tstamp:28094845980 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:899034258080 data:0x0000000000000010
 kworker/4:0-47      [004] .......   895.227679: rtcpu_vinotify_event: tstamp:28094846203 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:899034258080 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.227680: rtcpu_vinotify_event: tstamp:28094846452 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:899034885408 data:0x0000000000000001
 kworker/4:0-47      [004] .......   895.227680: rtcpu_vinotify_event: tstamp:28094846667 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899034886944 data:0x000000000802000a
 kworker/4:0-47      [004] .......   895.227681: rtcpu_vinotify_event: tstamp:28094846910 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:899034887968 data:0x0000000000000100
 kworker/4:0-47      [004] .......   895.227681: rtcpu_vinotify_event: tstamp:28094847128 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899034898560 data:0x000000000102000a
 kworker/4:0-47      [004] .......   895.227681: rtcpu_vinotify_event: tstamp:28095210870 cch:0 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:0 vi_tstamp:899046492896 data:0x0000000000000000
 kworker/4:0-47      [004] .......   895.283678: rtcpu_vinotify_event: tstamp:28095872902 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:899057371744 data:0x0000000000000020
 kworker/4:0-47      [004] .......   895.283679: rtcpu_vinotify_event: tstamp:28095873147 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:899057371776 data:0x0438200001000000
 kworker/4:0-47      [004] .......   895.283679: rtcpu_vinotify_event: tstamp:28095873401 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:899057371776 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.283679: rtcpu_vinotify_event: tstamp:28095873646 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899057385664 data:0x000000000702000b
 kworker/4:0-47      [004] .......   895.283679: rtcpu_vinotify_event: tstamp:28095873869 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899057395776 data:0x559d550010000000
 kworker/4:0-47      [004] .......   895.283680: rtcpu_vinotify_event: tstamp:28095874109 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899057402944 data:0x000000003100000c
 kworker/4:0-47      [004] .......   895.283680: rtcpu_vinotify_event: tstamp:28095874324 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:899067592480 data:0x0000000000000010
 kworker/4:0-47      [004] .......   895.283680: rtcpu_vinotify_event: tstamp:28095874571 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:899067592480 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.283680: vi_frame_begin: tstamp:28095881869 cch:0 syncpt_id:281 syncpt_thresh:55 class_id:48
 kworker/4:0-47      [004] .......   895.283681: rtcpu_vinotify_event: tstamp:28096203913 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:899068219808 data:0x0000000000000001
 kworker/4:0-47      [004] .......   895.283681: rtcpu_vinotify_event: tstamp:28096204167 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899068221344 data:0x000000000802000b
 kworker/4:0-47      [004] .......   895.283682: rtcpu_vinotify_event: tstamp:28096204389 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:899068222336 data:0x0000000000000100
 kworker/4:0-47      [004] .......   895.283682: rtcpu_vinotify_event: tstamp:28096204633 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899068232928 data:0x000000000102000b
 kworker/4:0-47      [004] .......   895.283682: rtcpu_vinotify_event: tstamp:28096535063 cch:0 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:0 vi_tstamp:899079827296 data:0x0000000000000000
 kworker/4:0-47      [004] .......   895.283682: rtcpu_vinotify_event: tstamp:28096586347 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:899090706144 data:0x0000000000000020
 kworker/4:0-47      [004] .......   895.283682: rtcpu_vinotify_event: tstamp:28096586578 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:899090706144 data:0x0438200001000000
 kworker/4:0-47      [004] .......   895.283683: rtcpu_vinotify_event: tstamp:28096899175 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:899090706176 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.283683: rtcpu_vinotify_event: tstamp:28096899402 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899090722048 data:0x000000000702000c
 kworker/4:0-47      [004] .......   895.283683: rtcpu_vinotify_event: tstamp:28096899654 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899090741600 data:0x559d580010000000
 kworker/4:0-47      [004] .......   895.283683: rtcpu_vinotify_event: tstamp:28096899872 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899090748768 data:0x000000003100000d
 kworker/4:0-47      [004] .......   895.283684: vi_frame_begin: tstamp:28096923568 cch:0 syncpt_id:281 syncpt_thresh:60 class_id:48
 kworker/4:0-47      [004] .......   895.339680: rtcpu_vinotify_event: tstamp:28097230237 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:899100926880 data:0x0000000000000010
 kworker/4:0-47      [004] .......   895.339681: rtcpu_vinotify_event: tstamp:28097230469 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:899100926880 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.339681: rtcpu_vinotify_event: tstamp:28097230723 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:899101554176 data:0x0000000000000001
 kworker/4:0-47      [004] .......   895.339681: rtcpu_vinotify_event: tstamp:28097230943 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899101555712 data:0x000000000802000c
 kworker/4:0-47      [004] .......   895.339681: rtcpu_vinotify_event: tstamp:28097231190 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:899101556736 data:0x0000000000000100
 kworker/4:0-47      [004] .......   895.339682: rtcpu_vinotify_event: tstamp:28097231407 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899101567360 data:0x000000000102000c
 kworker/4:0-47      [004] .......   895.339682: rtcpu_vinotify_event: tstamp:28097561208 cch:0 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:0 vi_tstamp:899113161664 data:0x0000000000000000
 kworker/4:0-47      [004] .......   895.339682: rtcpu_vinotify_event: tstamp:28097628550 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:899124040544 data:0x0000000000000020
 kworker/4:0-47      [004] .......   895.339682: rtcpu_vinotify_event: tstamp:28097628793 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:899124040544 data:0x0438200001000000
 kworker/4:0-47      [004] .......   895.339683: rtcpu_vinotify_event: tstamp:28097629018 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:899124040544 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.339683: rtcpu_vinotify_event: tstamp:28097629262 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899124054464 data:0x000000000702000d
 kworker/4:0-47      [004] .......   895.339683: rtcpu_vinotify_event: tstamp:28097629482 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899124067968 data:0x559d550010000000
 kworker/4:0-47      [004] .......   895.339683: rtcpu_vinotify_event: tstamp:28097958396 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899124087488 data:0x000000003100000e
 kworker/4:0-47      [004] .......   895.339684: rtcpu_vinotify_event: tstamp:28097958619 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:899134261280 data:0x0000000000000010
 kworker/4:0-47      [004] .......   895.339684: rtcpu_vinotify_event: tstamp:28097958870 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:899134261280 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.339684: vi_frame_begin: tstamp:28097965268 cch:0 syncpt_id:281 syncpt_thresh:65 class_id:48
 kworker/4:0-47      [004] .......   895.339684: rtcpu_vinotify_event: tstamp:28098289575 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:899134888576 data:0x0000000000000001
 kworker/4:0-47      [004] .......   895.339685: rtcpu_vinotify_event: tstamp:28098289831 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899134890112 data:0x000000000802000d
 kworker/4:0-47      [004] .......   895.339685: rtcpu_vinotify_event: tstamp:28098290057 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:899134891136 data:0x0000000000000100
 kworker/4:0-47      [004] .......   895.339685: rtcpu_vinotify_event: tstamp:28098290303 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899134901760 data:0x000000000102000d
 kworker/4:0-47      [004] .......   895.339685: rtcpu_vinotify_event: tstamp:28098620539 cch:0 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:0 vi_tstamp:899146496032 data:0x0000000000000000
 kworker/4:0-47      [004] .......   895.339686: rtcpu_vinotify_event: tstamp:28098951517 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:899157374944 data:0x0000000000000020
 kworker/4:0-47      [004] .......   895.339686: rtcpu_vinotify_event: tstamp:28098951741 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:899157374944 data:0x0438200001000000
 kworker/4:0-47      [004] .......   895.339686: rtcpu_vinotify_event: tstamp:28098951994 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:899157374944 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.339686: rtcpu_vinotify_event: tstamp:28098952213 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899157388864 data:0x000000000702000e
 kworker/4:0-47      [004] .......   895.339687: rtcpu_vinotify_event: tstamp:28098952457 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899157403392 data:0x559d580010000000
 kworker/4:0-47      [004] .......   895.339687: rtcpu_vinotify_event: tstamp:28098952674 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899157410560 data:0x000000003100000f
 kworker/4:0-47      [004] .......   895.395675: rtcpu_vinotify_event: tstamp:28098988872 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:899167595648 data:0x0000000000000010
 kworker/4:0-47      [004] .......   895.395675: rtcpu_vinotify_event: tstamp:28098989105 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:899167595680 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.395676: vi_frame_begin: tstamp:28099006968 cch:0 syncpt_id:281 syncpt_thresh:70 class_id:48
 kworker/4:0-47      [004] .......   895.395676: rtcpu_vinotify_event: tstamp:28099315775 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:899168222976 data:0x0000000000000001
 kworker/4:0-47      [004] .......   895.395676: rtcpu_vinotify_event: tstamp:28099316002 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899168224512 data:0x000000000802000e
 kworker/4:0-47      [004] .......   895.395677: rtcpu_vinotify_event: tstamp:28099316254 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:899168225504 data:0x0000000000000100
 kworker/4:0-47      [004] .......   895.395677: rtcpu_vinotify_event: tstamp:28099316470 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899168236128 data:0x000000000102000e
 kworker/4:0-47      [004] .......   895.395677: rtcpu_vinotify_event: tstamp:28099646718 cch:0 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:0 vi_tstamp:899179830432 data:0x0000000000000000
 kworker/4:0-47      [004] .......   895.395677: rtcpu_vinotify_event: tstamp:28099977833 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:899190709312 data:0x0000000000000020
 kworker/4:0-47      [004] .......   895.395678: rtcpu_vinotify_event: tstamp:28099978081 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:899190709312 data:0x0438200001000000
 kworker/4:0-47      [004] .......   895.395678: rtcpu_vinotify_event: tstamp:28099978306 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:899190709344 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.395678: rtcpu_vinotify_event: tstamp:28099978550 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899190723264 data:0x000000000702000f
 kworker/4:0-47      [004] .......   895.395678: rtcpu_vinotify_event: tstamp:28099978768 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899190734336 data:0x559d550010000000
 kworker/4:0-47      [004] .......   895.395678: rtcpu_vinotify_event: tstamp:28099979008 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899190741472 data:0x0000000031000010
 kworker/4:0-47      [004] .......   895.395679: vi_frame_begin: tstamp:28100048668 cch:0 syncpt_id:281 syncpt_thresh:75 class_id:48
 kworker/4:0-47      [004] .......   895.395679: rtcpu_vinotify_event: tstamp:28100054546 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:899200930048 data:0x0000000000000010
 kworker/4:0-47      [004] .......   895.395680: rtcpu_vinotify_event: tstamp:28100054795 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:899200930048 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.395680: rtcpu_vinotify_event: tstamp:28100055014 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:899201557376 data:0x0000000000000001
 kworker/4:0-47      [004] .......   895.395680: rtcpu_vinotify_event: tstamp:28100055257 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899201558944 data:0x000000000802000f
 kworker/4:0-47      [004] .......   895.395681: rtcpu_vinotify_event: tstamp:28100055539 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:899201559904 data:0x0000000000000100
 kworker/4:0-47      [004] .......   895.395681: rtcpu_vinotify_event: tstamp:28100375158 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899201571904 data:0x000000000102000f
 kworker/4:0-47      [004] .......   895.395681: rtcpu_vinotify_event: tstamp:28100706081 cch:0 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:0 vi_tstamp:899213164864 data:0x0000000000000000
 kworker/4:0-47      [004] .......   895.455678: rtcpu_vinotify_event: tstamp:28101037200 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:899224043712 data:0x0000000000000020
 kworker/4:0-47      [004] .......   895.455679: rtcpu_vinotify_event: tstamp:28101037423 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:899224043712 data:0x0438200001000000
 kworker/4:0-47      [004] .......   895.455679: rtcpu_vinotify_event: tstamp:28101037676 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:899224043744 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.455679: rtcpu_vinotify_event: tstamp:28101037898 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899224057632 data:0x0000000007020010
 kworker/4:0-47      [004] .......   895.455680: rtcpu_vinotify_event: tstamp:28101038142 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899224071328 data:0x559d580010000000
 kworker/4:0-47      [004] .......   895.455680: rtcpu_vinotify_event: tstamp:28101038358 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899224078528 data:0x0000000031000011
 kworker/4:0-47      [004] .......   895.455680: vi_frame_begin: tstamp:28101090368 cch:0 syncpt_id:281 syncpt_thresh:80 class_id:48
 kworker/4:0-47      [004] .......   895.455681: rtcpu_vinotify_event: tstamp:28101368251 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:899234264448 data:0x0000000000000010
 kworker/4:0-47      [004] .......   895.455681: rtcpu_vinotify_event: tstamp:28101368476 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:899234264448 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.455681: rtcpu_vinotify_event: tstamp:28101368724 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:899234891776 data:0x0000000000000001
 kworker/4:0-47      [004] .......   895.455681: rtcpu_vinotify_event: tstamp:28101368944 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899234893312 data:0x0000000008020010
 kworker/4:0-47      [004] .......   895.455682: rtcpu_vinotify_event: tstamp:28101369188 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:899234894304 data:0x0000000000000100
 kworker/4:0-47      [004] .......   895.455682: rtcpu_vinotify_event: tstamp:28101369407 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899234904928 data:0x0000000001020010
 kworker/4:0-47      [004] .......   895.455682: rtcpu_vinotify_event: tstamp:28101699193 cch:0 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:0 vi_tstamp:899246499232 data:0x0000000000000000
 kworker/4:0-47      [004] .......   895.455682: rtcpu_vinotify_event: tstamp:28101794842 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:899257378112 data:0x0000000000000020
 kworker/4:0-47      [004] .......   895.455683: rtcpu_vinotify_event: tstamp:28102096404 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:899257378112 data:0x0438200001000000
 kworker/4:0-47      [004] .......   895.455683: rtcpu_vinotify_event: tstamp:28102096631 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:899257378112 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.455683: rtcpu_vinotify_event: tstamp:28102096875 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899257394048 data:0x0000000007020011
 kworker/4:0-47      [004] .......   895.455683: rtcpu_vinotify_event: tstamp:28102097093 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899257409632 data:0x559d550010000000
 kworker/4:0-47      [004] .......   895.455683: rtcpu_vinotify_event: tstamp:28102097342 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899257419008 data:0x0000000031000012
 kworker/4:0-47      [004] .......   895.455684: vi_frame_begin: tstamp:28102132068 cch:0 syncpt_id:281 syncpt_thresh:85 class_id:48
 kworker/4:0-47      [004] .......   895.455684: rtcpu_vinotify_event: tstamp:28102427545 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:899267598848 data:0x0000000000000010
 kworker/4:0-47      [004] .......   895.455684: rtcpu_vinotify_event: tstamp:28102427801 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:899267598848 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.455685: rtcpu_vinotify_event: tstamp:28102428024 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:899268226176 data:0x0000000000000001
 kworker/4:0-47      [004] .......   895.455685: rtcpu_vinotify_event: tstamp:28102428270 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899268227712 data:0x0000000008020011
 kworker/4:0-47      [004] .......   895.455685: rtcpu_vinotify_event: tstamp:28102428487 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:899268228704 data:0x0000000000000100
 kworker/4:0-47      [004] .......   895.455685: rtcpu_vinotify_event: tstamp:28102428725 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899268239328 data:0x0000000001020011
 kworker/4:0-47      [004] .......   895.511676: rtcpu_vinotify_event: tstamp:28102758540 cch:0 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:0 vi_tstamp:899279833632 data:0x0000000000000000
 kworker/4:0-47      [004] .......   895.511677: rtcpu_vinotify_event: tstamp:28102836699 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:899290712512 data:0x0000000000000020
 kworker/4:0-47      [004] .......   895.511677: rtcpu_vinotify_event: tstamp:28102836924 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:899290712512 data:0x0438200001000000
 kworker/4:0-47      [004] .......   895.511677: rtcpu_vinotify_event: tstamp:28102837178 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:899290712512 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.511677: rtcpu_vinotify_event: tstamp:28102837394 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899290726432 data:0x0000000007020012
 kworker/4:0-47      [004] .......   895.511677: rtcpu_vinotify_event: tstamp:28103155949 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899290749920 data:0x559d580010000000
 kworker/4:0-47      [004] .......   895.511677: rtcpu_vinotify_event: tstamp:28103156172 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899290756384 data:0x0000000031000013
 kworker/4:0-47      [004] .......   895.511678: rtcpu_vinotify_event: tstamp:28103156408 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:899300933216 data:0x0000000000000010
 kworker/4:0-47      [004] .......   895.511678: rtcpu_vinotify_event: tstamp:28103156627 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:899300933248 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.511678: vi_frame_begin: tstamp:28103173768 cch:0 syncpt_id:281 syncpt_thresh:90 class_id:48
 kworker/4:0-47      [004] .......   895.511678: rtcpu_vinotify_event: tstamp:28103486950 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:899301560576 data:0x0000000000000001
 kworker/4:0-47      [004] .......   895.511678: rtcpu_vinotify_event: tstamp:28103487186 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899301562080 data:0x0000000008020012
 kworker/4:0-47      [004] .......   895.511679: rtcpu_vinotify_event: tstamp:28103487432 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:899301563104 data:0x0000000000000100
 kworker/4:0-47      [004] .......   895.511679: rtcpu_vinotify_event: tstamp:28103487650 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899301573728 data:0x0000000001020012
 kworker/4:0-47      [004] .......   895.511679: rtcpu_vinotify_event: tstamp:28103817919 cch:0 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:0 vi_tstamp:899313168000 data:0x0000000000000000
 kworker/4:0-47      [004] .......   895.511679: rtcpu_vinotify_event: tstamp:28104148868 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:899324046912 data:0x0000000000000020
 kworker/4:0-47      [004] .......   895.511679: rtcpu_vinotify_event: tstamp:28104149175 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:899324046912 data:0x0438200001000000
 kworker/4:0-47      [004] .......   895.511679: rtcpu_vinotify_event: tstamp:28104149401 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:899324046912 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.511680: rtcpu_vinotify_event: tstamp:28104149651 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899324060800 data:0x0000000007020013
 kworker/4:0-47      [004] .......   895.511680: rtcpu_vinotify_event: tstamp:28104149866 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899324074880 data:0x559d550010000000
 kworker/4:0-47      [004] .......   895.511680: rtcpu_vinotify_event: tstamp:28104150102 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899324082048 data:0x0000000031000014
 kworker/4:0-47      [004] .......   895.511680: rtcpu_vinotify_event: tstamp:28104197374 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:899334267616 data:0x0000000000000010
 kworker/4:0-47      [004] .......   895.511680: vi_frame_begin: tstamp:28104215468 cch:0 syncpt_id:281 syncpt_thresh:95 class_id:48
 kworker/4:0-47      [004] .......   895.567677: rtcpu_vinotify_event: tstamp:28104513122 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:899334267648 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.567677: rtcpu_vinotify_event: tstamp:28104513352 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:899334894976 data:0x0000000000000001
 kworker/4:0-47      [004] .......   895.567677: rtcpu_vinotify_event: tstamp:28104513607 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899334896480 data:0x0000000008020013
 kworker/4:0-47      [004] .......   895.567678: rtcpu_vinotify_event: tstamp:28104513822 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:899334897504 data:0x0000000000000100
 kworker/4:0-47      [004] .......   895.567678: rtcpu_vinotify_event: tstamp:28104514069 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899334908096 data:0x0000000001020013
 kworker/4:0-47      [004] .......   895.567678: rtcpu_vinotify_event: tstamp:28104844088 cch:0 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:0 vi_tstamp:899346502432 data:0x0000000000000000
 kworker/4:0-47      [004] .......   895.567678: rtcpu_vinotify_event: tstamp:28105175207 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:899357381312 data:0x0000000000000020
 kworker/4:0-47      [004] .......   895.567679: rtcpu_vinotify_event: tstamp:28105175429 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:899357381312 data:0x0438200001000000
 kworker/4:0-47      [004] .......   895.567679: rtcpu_vinotify_event: tstamp:28105175687 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:899357381312 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.567679: rtcpu_vinotify_event: tstamp:28105175906 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899357395200 data:0x0000000007020014
 kworker/4:0-47      [004] .......   895.567679: rtcpu_vinotify_event: tstamp:28105176150 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899357406624 data:0x559d580010000000
 kworker/4:0-47      [004] .......   895.567679: rtcpu_vinotify_event: tstamp:28105176367 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899357413792 data:0x0000000031000015
 kworker/4:0-47      [004] .......   895.567680: vi_frame_begin: tstamp:28105257167 cch:0 syncpt_id:281 syncpt_thresh:100 class_id:48
 kworker/4:0-47      [004] .......   895.567681: rtcpu_vinotify_event: tstamp:28105262938 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:899367602016 data:0x0000000000000010
 kworker/4:0-47      [004] .......   895.567681: rtcpu_vinotify_event: tstamp:28105263166 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:899367602016 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.567681: rtcpu_vinotify_event: tstamp:28105263414 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:899368229344 data:0x0000000000000001
 kworker/4:0-47      [004] .......   895.567681: rtcpu_vinotify_event: tstamp:28105263629 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899368230976 data:0x0000000008020014
 kworker/4:0-47      [004] .......   895.567682: rtcpu_vinotify_event: tstamp:28105572479 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:899368231904 data:0x0000000000000100
 kworker/4:0-47      [004] .......   895.567682: rtcpu_vinotify_event: tstamp:28105572702 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899368244896 data:0x0000000001020014
 kworker/4:0-47      [004] .......   895.567682: rtcpu_vinotify_event: tstamp:28105903448 cch:0 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:0 vi_tstamp:899379836832 data:0x0000000000000000
 kworker/4:0-47      [004] .......   895.623677: rtcpu_vinotify_event: tstamp:28106234572 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:899390715712 data:0x0000000000000020
 kworker/4:0-47      [004] .......   895.623678: rtcpu_vinotify_event: tstamp:28106234826 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:899390715712 data:0x0438200001000000
 kworker/4:0-47      [004] .......   895.623678: rtcpu_vinotify_event: tstamp:28106235049 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:899390715712 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.623678: rtcpu_vinotify_event: tstamp:28106235290 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899390729600 data:0x0000000007020015
 kworker/4:0-47      [004] .......   895.623678: rtcpu_vinotify_event: tstamp:28106235504 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899390742976 data:0x559d550010000000
 kworker/4:0-47      [004] .......   895.623678: rtcpu_vinotify_event: tstamp:28106235743 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899390750144 data:0x0000000031000016
 kworker/4:0-47      [004] .......   895.623679: vi_frame_begin: tstamp:28106298867 cch:0 syncpt_id:281 syncpt_thresh:105 class_id:48
 kworker/4:0-47      [004] .......   895.623679: rtcpu_vinotify_event: tstamp:28106565557 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:899400936416 data:0x0000000000000010
 kworker/4:0-47      [004] .......   895.623679: rtcpu_vinotify_event: tstamp:28106565815 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:899400936416 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.623679: rtcpu_vinotify_event: tstamp:28106566040 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:899401563744 data:0x0000000000000001
 kworker/4:0-47      [004] .......   895.623680: rtcpu_vinotify_event: tstamp:28106566286 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899401565248 data:0x0000000008020015
 kworker/4:0-47      [004] .......   895.623680: rtcpu_vinotify_event: tstamp:28106566501 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:899401566272 data:0x0000000000000100
 kworker/4:0-47      [004] .......   895.623680: rtcpu_vinotify_event: tstamp:28106566741 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899401576864 data:0x0000000001020015
 kworker/4:0-47      [004] .......   895.623680: rtcpu_vinotify_event: tstamp:28106663052 cch:0 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:0 vi_tstamp:899413171232 data:0x0000000000000000
 kworker/4:0-47      [004] .......   895.623680: rtcpu_vinotify_event: tstamp:28107028930 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:899424050112 data:0x0000000000000020
 kworker/4:0-47      [004] .......   895.623680: rtcpu_vinotify_event: tstamp:28107029156 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:899424050112 data:0x0438200001000000
 kworker/4:0-47      [004] .......   895.623681: rtcpu_vinotify_event: tstamp:28107029407 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:899424050112 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.623681: rtcpu_vinotify_event: tstamp:28107029625 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899424064000 data:0x0000000007020016
 kworker/4:0-47      [004] .......   895.623681: rtcpu_vinotify_event: tstamp:28107029870 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899424072928 data:0x559d580010000000
 kworker/4:0-47      [004] .......   895.623681: rtcpu_vinotify_event: tstamp:28107030085 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899424080576 data:0x0000000031000017
 kworker/4:0-47      [004] .......   895.623681: vi_frame_begin: tstamp:28107340567 cch:0 syncpt_id:281 syncpt_thresh:110 class_id:48
 kworker/4:0-47      [004] .......   895.623682: rtcpu_vinotify_event: tstamp:28107360085 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:899434270816 data:0x0000000000000010
 kworker/4:0-47      [004] .......   895.623682: rtcpu_vinotify_event: tstamp:28107360312 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:899434270816 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.623682: rtcpu_vinotify_event: tstamp:28107360565 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:899434898144 data:0x0000000000000001
 kworker/4:0-47      [004] .......   895.623682: rtcpu_vinotify_event: tstamp:28107360783 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899434899680 data:0x0000000008020016
 kworker/4:0-47      [004] .......   895.623682: rtcpu_vinotify_event: tstamp:28107361027 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:899434900672 data:0x0000000000000100
 kworker/4:0-47      [004] .......   895.623683: rtcpu_vinotify_event: tstamp:28107361243 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899434911296 data:0x0000000001020016
 kworker/4:0-47      [004] .......   895.679677: rtcpu_vinotify_event: tstamp:28108022164 cch:0 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:0 vi_tstamp:899446505600 data:0x0000000000000000
 kworker/4:0-47      [004] .......   895.679678: rtcpu_vinotify_event: tstamp:28108045063 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:899457384480 data:0x0000000000000020
 kworker/4:0-47      [004] .......   895.679678: rtcpu_vinotify_event: tstamp:28108045307 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:899457384512 data:0x0438200001000000
 kworker/4:0-47      [004] .......   895.679678: rtcpu_vinotify_event: tstamp:28108045532 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:899457384512 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.679678: rtcpu_vinotify_event: tstamp:28108353146 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899457399680 data:0x0000000007020017
 kworker/4:0-47      [004] .......   895.679679: rtcpu_vinotify_event: tstamp:28108353371 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899457420640 data:0x559d550010000000
 kworker/4:0-47      [004] .......   895.679679: rtcpu_vinotify_event: tstamp:28108353615 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899457427776 data:0x0000000031000018
 kworker/4:0-47      [004] .......   895.679679: vi_frame_begin: tstamp:28108382267 cch:0 syncpt_id:281 syncpt_thresh:115 class_id:48
 kworker/4:0-47      [004] .......   895.679680: rtcpu_vinotify_event: tstamp:28108684131 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:899467605216 data:0x0000000000000010
 kworker/4:0-47      [004] .......   895.679680: rtcpu_vinotify_event: tstamp:28108684389 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:899467605216 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.679680: rtcpu_vinotify_event: tstamp:28108684612 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:899468232544 data:0x0000000000000001
 kworker/4:0-47      [004] .......   895.679680: rtcpu_vinotify_event: tstamp:28108684857 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899468234048 data:0x0000000008020017
 kworker/4:0-47      [004] .......   895.679680: rtcpu_vinotify_event: tstamp:28108685076 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:899468235072 data:0x0000000000000100
 kworker/4:0-47      [004] .......   895.679680: rtcpu_vinotify_event: tstamp:28108685318 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899468245696 data:0x0000000001020017
 kworker/4:0-47      [004] .......   895.679681: rtcpu_vinotify_event: tstamp:28109015296 cch:0 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:0 vi_tstamp:899479840032 data:0x0000000000000000
 kworker/4:0-47      [004] .......   895.679681: rtcpu_vinotify_event: tstamp:28109087399 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:899490718880 data:0x0000000000000020
 kworker/4:0-47      [004] .......   895.679681: rtcpu_vinotify_event: tstamp:28109087619 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:899490718880 data:0x0438200001000000
 kworker/4:0-47      [004] .......   895.679681: rtcpu_vinotify_event: tstamp:28109087868 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:899490718912 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.679681: rtcpu_vinotify_event: tstamp:28109088087 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899490732800 data:0x0000000007020018
 kworker/4:0-47      [004] .......   895.679682: rtcpu_vinotify_event: tstamp:28109088328 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899490741760 data:0x559d580010000000
 kworker/4:0-47      [004] .......   895.679682: rtcpu_vinotify_event: tstamp:28109088546 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899490748928 data:0x0000000031000019
 kworker/4:0-47      [004] .......   895.679682: rtcpu_vinotify_event: tstamp:28109412536 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:899500939616 data:0x0000000000000010
 kworker/4:0-47      [004] .......   895.679682: rtcpu_vinotify_event: tstamp:28109412771 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:899500939616 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.679682: vi_frame_begin: tstamp:28109423966 cch:0 syncpt_id:281 syncpt_thresh:120 class_id:48
 kworker/4:0-47      [004] .......   895.735673: rtcpu_vinotify_event: tstamp:28109743598 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:899501566912 data:0x0000000000000001
 kworker/4:0-47      [004] .......   895.735673: rtcpu_vinotify_event: tstamp:28109743828 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899501568480 data:0x0000000008020018
 kworker/4:0-47      [004] .......   895.735673: rtcpu_vinotify_event: tstamp:28109744079 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:899501569472 data:0x0000000000000100
 kworker/4:0-47      [004] .......   895.735673: rtcpu_vinotify_event: tstamp:28109744297 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899501580064 data:0x0000000001020018
 kworker/4:0-47      [004] .......   895.735674: rtcpu_vinotify_event: tstamp:28110074512 cch:0 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:0 vi_tstamp:899513174400 data:0x0000000000000000
 kworker/4:0-47      [004] .......   895.735674: rtcpu_vinotify_event: tstamp:28110405618 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:899524053280 data:0x0000000000000020
 kworker/4:0-47      [004] .......   895.735674: rtcpu_vinotify_event: tstamp:28110405862 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:899524053280 data:0x0438200001000000
 kworker/4:0-47      [004] .......   895.735674: rtcpu_vinotify_event: tstamp:28110406085 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:899524053280 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.735674: rtcpu_vinotify_event: tstamp:28110406329 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899524067200 data:0x0000000007020019
 kworker/4:0-47      [004] .......   895.735675: rtcpu_vinotify_event: tstamp:28110406547 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899524078880 data:0x559d550010000000
 kworker/4:0-47      [004] .......   895.735675: rtcpu_vinotify_event: tstamp:28110406789 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899524086048 data:0x000000003100001a
 kworker/4:0-47      [004] .......   895.735676: vi_frame_begin: tstamp:28110465666 cch:0 syncpt_id:281 syncpt_thresh:125 class_id:48
 kworker/4:0-47      [004] .......   895.735676: rtcpu_vinotify_event: tstamp:28110471461 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:899534274016 data:0x0000000000000010
 kworker/4:0-47      [004] .......   895.735676: rtcpu_vinotify_event: tstamp:28110471715 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:899534274016 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.735676: rtcpu_vinotify_event: tstamp:28110471937 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:899534901312 data:0x0000000000000001
 kworker/4:0-47      [004] .......   895.735676: rtcpu_vinotify_event: tstamp:28110769844 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899534904160 data:0x0000000008020019
 kworker/4:0-47      [004] .......   895.735677: rtcpu_vinotify_event: tstamp:28110770071 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:899534903840 data:0x0000000000000100
 kworker/4:0-47      [004] .......   895.735677: rtcpu_vinotify_event: tstamp:28110770320 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899534916800 data:0x0000000001020019
 kworker/4:0-47      [004] .......   895.735677: rtcpu_vinotify_event: tstamp:28111100823 cch:0 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:0 vi_tstamp:899546508768 data:0x0000000000000000
 kworker/4:0-47      [004] .......   895.791676: rtcpu_vinotify_event: tstamp:28111431769 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:899557387680 data:0x0000000000000020
 kworker/4:0-47      [004] .......   895.791677: rtcpu_vinotify_event: tstamp:28111431995 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:899557387680 data:0x0438200001000000
 kworker/4:0-47      [004] .......   895.791677: rtcpu_vinotify_event: tstamp:28111432252 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:899557387680 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.791677: rtcpu_vinotify_event: tstamp:28111432474 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899557401600 data:0x000000000702001a
 kworker/4:0-47      [004] .......   895.791677: rtcpu_vinotify_event: tstamp:28111432720 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899557414688 data:0x559d580010000000
 kworker/4:0-47      [004] .......   895.791678: rtcpu_vinotify_event: tstamp:28111432960 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899557421888 data:0x000000003100001b
 kworker/4:0-47      [004] .......   895.791678: vi_frame_begin: tstamp:28111507366 cch:0 syncpt_id:281 syncpt_thresh:130 class_id:48
 kworker/4:0-47      [004] .......   895.791678: rtcpu_vinotify_event: tstamp:28111513159 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:899567608384 data:0x0000000000000010
 kworker/4:0-47      [004] .......   895.791678: rtcpu_vinotify_event: tstamp:28111513386 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:899567608416 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.791679: rtcpu_vinotify_event: tstamp:28111513638 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:899568235712 data:0x0000000000000001
 kworker/4:0-47      [004] .......   895.791679: rtcpu_vinotify_event: tstamp:28111513857 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899568237248 data:0x000000000802001a
 kworker/4:0-47      [004] .......   895.791679: rtcpu_vinotify_event: tstamp:28111514101 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:899568238240 data:0x0000000000000100
 kworker/4:0-47      [004] .......   895.791679: rtcpu_vinotify_event: tstamp:28111514320 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899568248864 data:0x000000000102001a
 kworker/4:0-47      [004] .......   895.791679: rtcpu_vinotify_event: tstamp:28111895356 cch:0 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:0 vi_tstamp:899579843200 data:0x0000000000000000
 kworker/4:0-47      [004] .......   895.791680: rtcpu_vinotify_event: tstamp:28112226293 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:899590722080 data:0x0000000000000020
 kworker/4:0-47      [004] .......   895.791680: rtcpu_vinotify_event: tstamp:28112226543 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:899590722080 data:0x0438200001000000
 kworker/4:0-47      [004] .......   895.791680: rtcpu_vinotify_event: tstamp:28112226767 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:899590722080 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.791680: rtcpu_vinotify_event: tstamp:28112227012 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899590736032 data:0x000000000702001b
 kworker/4:0-47      [004] .......   895.791680: rtcpu_vinotify_event: tstamp:28112227231 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899590750080 data:0x559d550010000000
 kworker/4:0-47      [004] .......   895.791680: rtcpu_vinotify_event: tstamp:28112227482 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899590757248 data:0x000000003100001c
 kworker/4:0-47      [004] .......   895.791681: vi_frame_begin: tstamp:28112549066 cch:0 syncpt_id:281 syncpt_thresh:135 class_id:48
 kworker/4:0-47      [004] .......   895.791681: rtcpu_vinotify_event: tstamp:28112559743 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:899600942784 data:0x0000000000000010
 kworker/4:0-47      [004] .......   895.791681: rtcpu_vinotify_event: tstamp:28112559999 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:899600942784 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.791681: rtcpu_vinotify_event: tstamp:28112560223 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:899601570112 data:0x0000000000000001
 kworker/4:0-47      [004] .......   895.791681: rtcpu_vinotify_event: tstamp:28112560469 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899601571648 data:0x000000000802001b
 kworker/4:0-47      [004] .......   895.791681: rtcpu_vinotify_event: tstamp:28112560683 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:899601572640 data:0x0000000000000100
 kworker/4:0-47      [004] .......   895.791681: rtcpu_vinotify_event: tstamp:28112560919 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899601583264 data:0x000000000102001b
 kworker/4:0-47      [004] .......   895.847678: rtcpu_vinotify_event: tstamp:28113219525 cch:0 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:0 vi_tstamp:899613177600 data:0x0000000000000000
 kworker/4:0-47      [004] .......   895.847678: rtcpu_vinotify_event: tstamp:28113253541 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:899624056448 data:0x0000000000000020
 kworker/4:0-47      [004] .......   895.847678: rtcpu_vinotify_event: tstamp:28113253764 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:899624056448 data:0x0438200001000000
 kworker/4:0-47      [004] .......   895.847678: rtcpu_vinotify_event: tstamp:28113583546 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:899624056480 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.847678: rtcpu_vinotify_event: tstamp:28113583769 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899624072384 data:0x000000000702001c
 kworker/4:0-47      [004] .......   895.847679: rtcpu_vinotify_event: tstamp:28113584022 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899624092416 data:0x559d580010000000
 kworker/4:0-47      [004] .......   895.847679: rtcpu_vinotify_event: tstamp:28113584241 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899624099584 data:0x000000003100001d
 kworker/4:0-47      [004] .......   895.847679: rtcpu_vinotify_event: tstamp:28113584481 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:899634277152 data:0x0000000000000010
 kworker/4:0-47      [004] .......   895.847679: rtcpu_vinotify_event: tstamp:28113584707 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:899634277184 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.847679: vi_frame_begin: tstamp:28113590766 cch:0 syncpt_id:281 syncpt_thresh:140 class_id:48
 kworker/4:0-47      [004] .......   895.847680: rtcpu_vinotify_event: tstamp:28113914700 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:899634904512 data:0x0000000000000001
 kworker/4:0-47      [004] .......   895.847680: rtcpu_vinotify_event: tstamp:28113914929 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899634906048 data:0x000000000802001c
 kworker/4:0-47      [004] .......   895.847680: rtcpu_vinotify_event: tstamp:28113915180 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:899634907040 data:0x0000000000000100
 kworker/4:0-47      [004] .......   895.847680: rtcpu_vinotify_event: tstamp:28113915398 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899634917664 data:0x000000000102001c
 kworker/4:0-47      [004] .......   895.847681: rtcpu_vinotify_event: tstamp:28114245700 cch:0 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:0 vi_tstamp:899646511968 data:0x0000000000000000
 kworker/4:0-47      [004] .......   895.847681: rtcpu_vinotify_event: tstamp:28114295764 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:899657390848 data:0x0000000000000020
 kworker/4:0-47      [004] .......   895.847681: rtcpu_vinotify_event: tstamp:28114296010 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:899657390848 data:0x0438200001000000
 kworker/4:0-47      [004] .......   895.847681: rtcpu_vinotify_event: tstamp:28114296234 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:899657390848 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.847681: rtcpu_vinotify_event: tstamp:28114296485 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899657404768 data:0x000000000702001d
 kworker/4:0-47      [004] .......   895.847681: rtcpu_vinotify_event: tstamp:28114296702 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899657418560 data:0x559d550010000000
 kworker/4:0-47      [004] .......   895.847681: rtcpu_vinotify_event: tstamp:28114609840 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899657438080 data:0x000000003100001e
 kworker/4:0-47      [004] .......   895.847682: vi_frame_begin: tstamp:28114632466 cch:0 syncpt_id:281 syncpt_thresh:145 class_id:48
 kworker/4:0-47      [004] .......   895.903677: rtcpu_vinotify_event: tstamp:28114940814 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:899667611552 data:0x0000000000000010
 kworker/4:0-47      [004] .......   895.903677: rtcpu_vinotify_event: tstamp:28114941072 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:899667611584 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.903677: rtcpu_vinotify_event: tstamp:28114941298 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:899668238912 data:0x0000000000000001
 kworker/4:0-47      [004] .......   895.903677: rtcpu_vinotify_event: tstamp:28114941542 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899668240416 data:0x000000000802001d
 kworker/4:0-47      [004] .......   895.903678: rtcpu_vinotify_event: tstamp:28114941759 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:899668241440 data:0x0000000000000100
 kworker/4:0-47      [004] .......   895.903678: rtcpu_vinotify_event: tstamp:28114941999 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899668252064 data:0x000000000102001d
 kworker/4:0-47      [004] .......   895.903678: rtcpu_vinotify_event: tstamp:28115271977 cch:0 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:0 vi_tstamp:899679846368 data:0x0000000000000000
 kworker/4:0-47      [004] .......   895.903678: rtcpu_vinotify_event: tstamp:28115602921 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:899690725248 data:0x0000000000000020
 kworker/4:0-47      [004] .......   895.903678: rtcpu_vinotify_event: tstamp:28115603139 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:899690725248 data:0x0438200001000000
 kworker/4:0-47      [004] .......   895.903678: rtcpu_vinotify_event: tstamp:28115603397 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:899690725248 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.903678: rtcpu_vinotify_event: tstamp:28115603612 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899690739136 data:0x000000000702001e
 kworker/4:0-47      [004] .......   895.903679: rtcpu_vinotify_event: tstamp:28115603856 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899690753152 data:0x559d580010000000
 kworker/4:0-47      [004] .......   895.903680: rtcpu_vinotify_event: tstamp:28115604071 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899690760320 data:0x000000003100001f
 kworker/4:0-47      [004] .......   895.903680: rtcpu_vinotify_event: tstamp:28115656072 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:899700945952 data:0x0000000000000010
 kworker/4:0-47      [004] .......   895.903680: rtcpu_vinotify_event: tstamp:28115656321 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:899700945984 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.903680: vi_frame_begin: tstamp:28115674166 cch:0 syncpt_id:281 syncpt_thresh:150 class_id:48
 kworker/4:0-47      [004] .......   895.903680: rtcpu_vinotify_event: tstamp:28115967169 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:899701573312 data:0x0000000000000001
 kworker/4:0-47      [004] .......   895.903680: rtcpu_vinotify_event: tstamp:28115967396 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899701574816 data:0x000000000802001e
 kworker/4:0-47      [004] .......   895.903681: rtcpu_vinotify_event: tstamp:28115967645 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:899701575840 data:0x0000000000000100
 kworker/4:0-47      [004] .......   895.903681: rtcpu_vinotify_event: tstamp:28115967862 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899701586432 data:0x000000000102001e
 kworker/4:0-47      [004] .......   895.903681: rtcpu_vinotify_event: tstamp:28116298135 cch:0 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:0 vi_tstamp:899713180736 data:0x0000000000000000
 kworker/4:0-47      [004] .......   895.963675: rtcpu_vinotify_event: tstamp:28116629248 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:899724059648 data:0x0000000000000020
 kworker/4:0-47      [004] .......   895.963676: rtcpu_vinotify_event: tstamp:28116629503 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:899724059648 data:0x0438200001000000
 kworker/4:0-47      [004] .......   895.963676: rtcpu_vinotify_event: tstamp:28116629726 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:899724059648 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.963676: rtcpu_vinotify_event: tstamp:28116629970 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899724073536 data:0x000000000702001f
 kworker/4:0-47      [004] .......   895.963677: rtcpu_vinotify_event: tstamp:28116630188 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899724084832 data:0x559d550010000000
 kworker/4:0-47      [004] .......   895.963677: rtcpu_vinotify_event: tstamp:28116630429 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899724092000 data:0x0000000031000020
 kworker/4:0-47      [004] .......   895.963677: vi_frame_begin: tstamp:28116715866 cch:0 syncpt_id:281 syncpt_thresh:155 class_id:48
 kworker/4:0-47      [004] .......   895.963677: rtcpu_vinotify_event: tstamp:28116721666 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:899734280352 data:0x0000000000000010
 kworker/4:0-47      [004] .......   895.963678: rtcpu_vinotify_event: tstamp:28116721915 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:899734280352 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.963678: rtcpu_vinotify_event: tstamp:28116722137 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:899734907712 data:0x0000000000000001
 kworker/4:0-47      [004] .......   895.963678: rtcpu_vinotify_event: tstamp:28116722379 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899734909216 data:0x000000000802001f
 kworker/4:0-47      [004] .......   895.963678: rtcpu_vinotify_event: tstamp:28116722595 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:899734910240 data:0x0000000000000100
 kworker/4:0-47      [004] .......   895.963679: rtcpu_vinotify_event: tstamp:28117026544 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899734922144 data:0x000000000102001f
 kworker/4:0-47      [004] .......   895.963679: rtcpu_vinotify_event: tstamp:28117357509 cch:0 vi:0 tag:ATOMP_FRAME_NLINES_DONE channel:0x23 frame:0 vi_tstamp:899746515136 data:0x0000000000000000
 kworker/4:0-47      [004] .......   895.963679: rtcpu_vinotify_event: tstamp:28117688457 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:899757394016 data:0x0000000000000020
 kworker/4:0-47      [004] .......   895.963679: rtcpu_vinotify_event: tstamp:28117688685 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:899757394016 data:0x0438200001000000
 kworker/4:0-47      [004] .......   895.963679: rtcpu_vinotify_event: tstamp:28117688935 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:899757394048 data:0x0000000800000000
 kworker/4:0-47      [004] .......   895.963680: rtcpu_vinotify_event: tstamp:28117689154 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:899757407968 data:0x0000000007020020
 kworker/4:0-47      [004] .......   895.963680: rtcpu_vinotify_event: tstamp:28117689398 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899757421600 data:0x559d580010000000
 kworker/4:0-47      [004] .......   895.963680: rtcpu_vinotify_event: tstamp:28117689613 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:899757428736 data:0x0000000031000021
Dear @shuaipeng.duan,
What is the camera module and used command ? May I know what you want to debug? Do you see any issue with camera data capture? Is it listed in DRIVE AGX Orin Sensors & Accessories | NVIDIA Developer ?
It’s not on this list.
I need to debug a new camera,max96712 MIPI output is available,but RCE Traces only have
vi_frame_begin does not have vi_frame_end.
csi has detected frame_begin. Why is frame_end not detected.
The same configuration(desers and serdes) works on other SOCs
Can you see from the log why there is no vi_frame_end ?
Is there another way to know why there is no frame_end ?
