After I configured link aggregation (Link Aggregation | DOCA), the system could not see the RDMA device.
The bond0 is the LAG port:
bond0: flags=5187<UP,BROADCAST,RUNNING,MASTER,MULTICAST> mtu 1500
inet6 2001:da8:9000:a806:844e:1ff:fe0a:33ca prefixlen 64 scopeid 0x0<global>
inet6 fe80::844e:1ff:fe0a:33ca prefixlen 64 scopeid 0x20<link>
ether 86:4e:01:0a:33:ca txqueuelen 1000 (Ethernet)
RX packets 119727 bytes 31467752 (31.4 MB)
RX errors 0 dropped 719 overruns 0 frame 0
TX packets 390 bytes 38432 (38.4 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
oob_net0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::a288:c2ff:fe32:68e prefixlen 64 scopeid 0x20<link>
ether a0:88:c2:32:06:8e txqueuelen 1000 (Ethernet)
RX packets 22 bytes 7348 (7.3 KB)
TX packets 40 bytes 9500 (9.5 KB)
p0: flags=6211<UP,BROADCAST,RUNNING,SLAVE,MULTICAST> mtu 1500
RX packets 59804 bytes 15727869 (15.7 MB)
RX errors 0 dropped 8 overruns 0 frame 0
TX packets 280 bytes 27209 (27.2 KB)
p1: flags=6211<UP,BROADCAST,RUNNING,SLAVE,MULTICAST> mtu 1500
RX packets 59954 bytes 15741963 (15.7 MB)
RX errors 0 dropped 695 overruns 0 frame 0
TX packets 124 bytes 12507 (12.5 KB)
pf0hpf: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::7cc5:9ff:fe14:d8e2 prefixlen 64 scopeid 0x20<link>
ether 7e:c5:09:14:d8:e2 txqueuelen 1000 (Ethernet)
RX packets 171 bytes 0 (0.0 B)
TX packets 104440 bytes 27424690 (27.4 MB)
pf1hpf: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::7409:70ff:fe87:176f prefixlen 64 scopeid 0x20<link>
ether 76:09:70:87:17:6f txqueuelen 1000 (Ethernet)
RX packets 14 bytes 0 (0.0 B)
TX packets 14 bytes 1076 (1.0 KB)
tmfifo_net0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.100.2 netmask 255.255.255.252 broadcast 192.168.100.3
inet6 fe80::21a:caff:feff:ff01 prefixlen 64 scopeid 0x20<link>
ether 00:1a:ca:ff:ff:01 txqueuelen 1000 (Ethernet)
RX packets 1309 bytes 126401 (126.4 KB)
TX packets 997 bytes 116795 (116.7 KB)
ac62dea6-219e-40a8-8b56-f5714ce9b4eb
Bridge bf-lag
Port pf0hpf
Interface pf0hpf
Port bond0
Interface bond0
Port bf-lag
Interface bf-lag
type: internal
ovs_version: "2.7.0-0056-24.01-based-2.17.8"
Could not find ibv deivce:
pinesl@localhost:~$ ibv_devinfo
No IB devices found
