I am trying to check working of RDMA with SoftRoCE. When I try to run rping it sends me “cma event RDMA_CM_EVENT_UNREACHABLE, error -110”
what can be the possible scenarios where this error can occur.
More details -
Server
port 1234
created cm_id 0x6090c0
rdma_bind_addr successful
rdma_listen
Client
port 1234
cma_event type RDMA_CM_EVENT_ADDR_RESOLVED cma_id 0x6090c0 (parent)
cma_event type RDMA_CM_EVENT_ROUTE_RESOLVED cma_id 0x6090c0 (parent)
rdma_resolve_addr - rdma_resolve_route successful
created pd 0x60b630
created channel 0x60b650
created cq 0x60b670
created qp 0x60b720
rping_setup_buffers called on cb 0x606010
allocated & registered buffers…
cq_thread started.
cma_event type RDMA_CM_EVENT_UNREACHABLE cma_id 0x6090c0 (parent)
Can you ping to the peer using linux ping (not the RDMA ping)?
What is the command line you used on both peers?
IBOE V2
Name Link Driver Speed NMTU IPv4_addr RDEV RMTU
p4p1 yes r8169 1500 10.213.64.106 rxe0 1024 (3)
wlan0 no rtl8192cu 1500
PING 10.213.64.106 (10.213.64.106) 56(84) bytes of data.
64 bytes from 10.213.64.106: icmp_seq=1 ttl=64 time=0.024 ms
I am able to ping the machine using linux ping
