RE: 900-13448-0020-000 Jetson Nano Module
Thank you for the earlier response.
However, our customer can only accept ‘699-13448-0002-401’ Internal Assembly Number.
Is there anyway we can identify this number without scanning the 2D QR code?
Can we validate this Internal Assmbly Number(above) with S/N or P/N printed on the label/card?
Your urgent reply will be appreciated!!
Thank you again!
Frank
May I ask what is the purpose of doing this?
Thanks for your reply. We need help to identify Internal Assembly Number without scanning the 2D barcode. There are over 1,000 units of Nvidia product 900-13448-0020-000 in stock, and there are multiple Internal Assembly number for the same product, however, our customer can only use Internal Assembly Number ‘699-13448-0002-401’. We now know we can get that info by scanning the 2D barcode, however, there are over 1,000pcs of them, it would be impossible to scan each and every of them. We would like to know is there anyway we can identify this number without scanning the 2D QR code?
不知道用中文問會不會更清楚一點. 我不太確定為何客戶會只能 “only use Internal Assembly Number ‘699-13448-0002-401’”. 這件事情不可能不掃QR code就知道.
感谢答复,根据pcn-206841,Nvidia在2020年增加了BOM Version/internal assembly number/dram-emmc-manufacturing-bom-expansion,新的dram-emmc需要升级软件之后才能正常使用,我们客户的软件还没有升级过,现在要赶生产进度来不及升级软件只能用pcn-206841之前的那个BOM Version/internal assembly number/dram-emmc-manufacturing-bom ‘699-13448-0002-401’
只能請你們盡快升級軟體了. 不可能用判斷module的方式來做這個
麻烦帮忙确认这个变更是从哪一年的什么时间点呢?如果是2022年生产的会不会都是同一个699 level number/BOM version/production number?
