Re-flashing JetPack 6.2 image, want to start from scratch due to dependency issues
So im working on a project that takes a voice and translate it into Spanish and then outputs the translated text to a speaker/headphones using openAI’s whisper models. I ran into virtual environment issues as well as some broken dependencies and I was not able to resolve them. So I wanted to reflash the Orin Nano to start from scratch, I’ve already done the setup up before (as I was using jetpack 6.2 to start with the project. I also ensured that the transition from 5.1.3 image went well to start using the 6.x images.) but I just wanted to ensure that reflashing it with the image I am using (jetpack 6.2) is fine.
However I did have a concern, since the transition between the old jetpacks was image 5.1.3 to transition to use the new jetpack 6.x images, if I already did this transition, hence me using jetpack 6.2, I dont need to do it again correct?
Yes, you don’t need to do the transition again.
I figured, thanks anyway!
