(re) how to set config file for multiple sources and kafka broker(sink type=6) in test5-app
Hi, thank you for your kind answer
I Re-upload the topic due to the late reply
The original topic is this
I did some debugging and found that “sink_sub_bin_sink2” was not added to the pipeline. But I couldn’t confirm the reason and I couldn’t check any other error messages.
I am most curious about whether it is possible to send the metadata of each video to each topic through multiple sinks while using deepstream.
If possible, I’d like to know the clear way. No matter how much I search the forum, I can’t find it, so I’m asking again
And I do not know exactly what the following words in the multi broker part of the READ-ME of the test-5 app
If I need to modify the app, I want to know how to do it and how to assign the id appropriately
These fields force converter / broker components to process only those messages having same value for componentId field and ignore other messages. User should modify the application to fill componentId field of NvDsEventMsgMeta structure.
Please countinue posting your issue at original topic: How to set config file for multiple sources and kafka broker(sink type=6) in test5-app - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums
thank you
I’ll wait for the answer to the last question I left on the original topic
Which one?
this topic
