Hi!
I was trying to re-install Jetpack onto TX1, but during the post-installation, after flashing os to TX1, it hangs at ‘copying (some files) to TX1’ then never finish.
I’m using Ubuntu 16.04 as Host and set opencv4Tegra to ‘no action’. It worked last time.
Do I need to keep the ethernet cable connected to the host? My TX1 has Wifi antenna.
Hi nothingworkswithme,
Yes, it’s suggested to use ethernet connection while flashing the device.
Please try again and share the result.
Hi!
So I did it again, but it still hangs at ‘Copying cuda-repo-l4t-8-0-local_8.0.34-1_arm64.deb file to target…’ not moving on.
Can anyone help?
Did you use wired ethernet on this last test? Is your host native Ubuntu or is it a VM?
Ok I solved it.
So it turns out I needed to use ethernet on the device to connect to the same modem of the host. Then it works
