Re-install nvv4l2decoder
I wanted to build and use the latest version of gstreamer, so I uninstalled the existing gstreamer (version 1.14) with the following command.
sudo apt-get remove --purge gstreamer1.0*
After that, I was able to install the latest gstreamer (version 1.23), but I noticed that elements such as nvv4l2decoder were not generated when I built the official gstreamer.
How can I install a gstreamer that can use nvv4l2decoder again?
I have performed the following steps but the required element was not restored.
https://docs.nvidia.com/jetson/archives/r35.2.1/DeveloperGuide/text/SD/Multimedia/AcceleratedGstreamer.html
The output of gst-inspect-1.0 | grep nv is below.
ivtc:  ivtc: Inverse Telecine
debugutilsbad:  errorignore: Convert some GstFlowReturn types into others
libav:  avdec_twinvq: libav VQF TwinVQ decoder
libav:  avdec_dsicinvideo: libav Delphine Software International CIN video decoder
libav:  avdec_idcinvideo: libav id Quake II CIN video decoder
libav:  avdec_wnv1: libav Winnov WNV1 decoder
audioconvert:  audioconvert: Audio converter
bayer:  rgb2bayer: RGB to Bayer converter
audiofx:  audioinvert: Audio inversion
videoconvert:  videoconvert: Colorspace converter
opengl:  glcolorconvert: OpenGL color converter
opengl:  gleffects_blur: Blur with 9x9 separable convolution Effect
opengl:  gleffects_laplacian: Laplacian Convolution Demo Effect
opengl:  glviewconvert: OpenGL Multiview/3D conversion filter
rtponvif:  rtponviftimestamp: ONVIF NTP timestamps RTP extension
rtponvif:  rtponvifparse: ONVIF NTP timestamps RTP extension
autoconvert:  autoconvert: Select convertor based on caps
autoconvert:  autovideoconvert: Select color space convertor based on caps
The default plugins are built with 1.14.5 and it may not work properly if you build the plugin with 1.23. Please note this.
Source code of the plugins is in
Jetson Linux R32.7.4 | NVIDIA Developer
Driver Package (BSP) Sources
Please download the package and follow README to build the plugins.
