Hi experts,
I have a server with the following info:
uname -r
4.18.0-553.22.1.el8_10.x86_64
rpm -qa | grep kernel | grep .22
kernel-modules-4.18.0-553.22.1.el8_10.x86_64
kernel-devel-4.18.0-553.22.1.el8_10.x86_64
kernel-headers-4.18.0-553.22.1.el8_10.x86_64
kernel-core-4.18.0-553.22.1.el8_10.x86_64
kernel-4.18.0-553.22.1.el8_10.x86_64
kernel-tools-4.18.0-553.22.1.el8_10.x86_64
kernel-tools-libs-4.18.0-553.22.1.el8_10.x86_64
lspci | grep -i nvidia
05:00.0 VGA compatible controller: NVIDIA Corporation GV100 [TITAN V] (rev a1)
05:00.1 Audio device: NVIDIA Corporation Device 10f2 (rev a1)
nvidia-smi is not working because of the kernel patch updates.
I install this NVIDIA-Linux-x86_64-550.100.run driver in the past and all was good but after patching when I try to re-install the same driver I see these messages in the /var/log/nvidia-installer.log
make[1]: Entering directory ‘/usr/src/kernels/4.18.0-553.22.1.el8_10.x86_64’
Makefile:1006: *** “Cannot generate ORC metadata for CONFIG_UNWINDER_ORC=y, please install libelf-dev, libelf-devel or elfutils-libelf-devel”. Stop.
make[1]: Leaving directory ‘/usr/src/kernels/4.18.0-553.22.1.el8_10.x86_64’
make: *** [Makefile:85: modules] Error 2
→ Error.
ERROR: An error occurred while performing the step: “Checking to see whether the nvidia kernel module was successfully built”. See /var/log/nvidia-installer.log for details.
→ The command cd kernel; /usr/bin/make -k -j8 NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/usr/src/kernels/4.18.0-553.22.1.el8_10.x86_64" SYSOUT="/usr/src/kernels/4.18.0-553.22.1.el8_10.x8 6_64" NV_KERNEL_MODULES="nvidia"
failed with the following output:
do you think I need to re-install kernel-header , kernel-devel and kernel-module?
