I have trained a Custom Trained Pytorch Mask-RCNN network which takes image as an input and gives outputs the bounding box, masks with class and class labels. I have used Mask-RCNN model directly for the torchvision v0.4.0. The training and data preprocessing code is similar to vision/references/segmentation at main · pytorch/vision · GitHub and to get mask-rcnn model I have just used from torchvision.models.detection import MaskRCNN with no changes and trained it for 2 classes.
I tried to test this trained model on Jetson Nano without any use of ONNX/ DeepStream/TensorRT conversion and the swap memory(4GB) and the main memory(4GB) got filled up just while loading the model. The model weights .pth file is of size 241MB(just for ref).
I just installed the pytorch 1.2.0 and torchvision 0.4.0 as per the ref: PyTorch for Jetson
Can someone tell me what I should do or how I should optimize this model to run on Jetson Nano. Is it possible to run this model in DeepStream or TensorRT? How can I convert the model to run in such system?
I’m new on this hardware, so in need of some guidance.
