I am looking into the code samples provided in /usr/local/cuda-11.8/extras/CUPTI/samples/pc_sampling_continuous/
. I am trying to get the PC stall reasons (from an executable) without modifying the source code using CUPTI. pc_sampling_continuous
seems to be doing exactly the same.
When I am running the command :
./libpc_sampling_continuous.pl --collection-mode 1 --sampling-period 7 --file-name pcsampling.dat --verbose --app "./executable_name"
, it outputs a dat
file.
To read this .dat
file, /usr/local/cuda-11.8/extras/CUPTI/samples/pc_sampling_utility/
contains an utility file. This is run with the command:
./pc_sampling_utility --file-name 1_pcsampling.dat
and it is able to output in a human readable format.
I have 2 problems regarding this:
It always says
lineNumber:0, fileName: ERROR_NO_CUBIN, dirName: ,
in each line. However it is able to show me the stalls. But without correlating to the line number in the code and SASS (both) , it is of no use. -
README
file tells that I should be using the cubin file for the source correlation. I am able to generate the cubin file (ascuobjdump -xelf all ./executable_name
and renaming it to1.cubin
). But I am not able to understand how to input this cubin file together with the.dat
file topc_sampling_utility
Any help is appreciated.
