Read Mipi-Csi data in different Resolution using v4l2 API in xavier NX
Hi Everyone,
I need to read different MIPI burst packet(different resolution) using V4l2 API.
I have configure different MIPI burst in my mode table in my custom sensor driver
example
1]
static const struct camera_common_frmfmt radarV01_frmfmt = {
{{32776, 1}, radarV01_900fps, 1, 0, RADARV01_MODE_32776X1_CROP_900FPS},
{{61448, 1}, radarV01_900fps, 1, 0, RADARV01_MODE_61448X1_CROP_900FPS},
I can read only 32776 * 1 resolution. If I try to read 61448 * 1 using v4l2-ctl command I can’t able to read data.
Commands
$v4l2-ctl -d /dev/video0 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: ‘RGGB’
Name : 8-bit Bayer RGRG/GBGB
Interval: Discrete 0.001s (900.000 fps)
$ v4l2-ctl --device /dev/video0 --set-fmt-video=width=61448,height=1,pixelformat=RGGB
$ v4l2-ctl -d /dev/video4 --set-fmt-video=width=61448,height=1,pixelformat=RGGB --set-ctrl bypass_mode=0 --stream-mmap --stream-count=40 --stream-to=IC1VC0.raw.
2]
I can read only 61448 * 1 resolution. If I try to read 32776 * 1 using v4l2-ctl command I can’t able to read data.
Commands
Index : 0
$ v4l2-ctl --device /dev/video0 --set-fmt-video=width=32776,height=1,pixelformat=RGGB
$ v4l2-ctl -d /dev/video4 --set-fmt-video=width=32776,height=1,pixelformat=RGGB --set-ctrl bypass_mode=0 --stream-mmap --stream-count=40 --stream-to=IC1VC0.raw.
If I try change also it’s set in default value.
Can you help me to solve this.
Thanks for your time.
