Read only file system /usr/lib/wsl/lib nvidia-smi
I have NVIDIA CUDA working on WSL 2 for docker images. However, I am trying to get it working for non-docker and I keep getting nvida-smi not found. The guide says to add it to the path. I did that. I see it in that directory but cannot execute it even when in the directory. It won’t find it.
-r-xr-xr-x 1 root root 600472 Jun 7 00:08 nvidia-smi
Trying execute gives Command ‘nvidia-smi’ not found, but can be installed with:
Trying change permissions says “read-only”. Thanks for the help.
