Hi everyone.
I intend to read rotary encoder using Jetson NANO GPiO. Can I use GPIO input pins (for example pin 12, working on 3.3V High level) to connect 5V (high level) encoder data signal? I’m not electrical engineer.
Thank You in advance.
Hi taliansky.alex,
Are you using the devkit or custom board for Jetson Nano?
Do you mean the PIN12 on 40-pins header?
Hi.
I’m using development kit jetson nano board with Jetpack 4.6 version.
Regarding pin number - yes, I mean physical pin 12 of the 40-pins header.
No, pin 12 can not bear 5V.
thank you!
