you’re able to execute chkbdinfo to dump platform information.
however,
you should note that its reading cvm.bin to extract the information.
cvm.bin was updated for the last flashing process and it stored to your local machine.
you may also found below during flashing the board,
[ 5.4775 ] Saved platform info in $OUT/Linux_for_Tegra/bootloader/cvm.bin
may I know what’s the use-case for reading the serial number while putting into forced-recovery mode?
thanks
Thank you for your information. But I could not understand your explanation completely.
You mean that the cvm.bin is software and the flash script was used it to read the Serial/Number. Is my understanding correct?
For our use-case, we would like to remain the evidence as log file while writing image per module.
Thank you for your information. I will check it. Dose this output value mean the serial number? Can we recognized this value from appearance of module? As you know all module has the unique serial number on each module label.
By the way, can be this command used for other jetson family?
