Read video streams from a queue and input them into DeepStream
• DeepStream Version
• TensorRT Version
• Issue Type( questions, new requirements, bugs) questions
Hello everyone,
I am looking to create a custom system, and my initial step is to generate video segments—such as 30-second clips—using FFmpeg.
Instead of saving these segments to disk, I plan to send them directly to a queue.
After that, I need to develop a custom DeepStream pipeline. DeepStream will pull the videos from the queue and feed them into the pipeline. As you may know, this process occurs quickly, and DeepStream will continue this cycle until all videos in the queue have been processed.
I also came across a similar question that lacked a solution, such as: Using VMS like Network Optix with DeepStream
Is it feasible to accomplish this task?
You can try the following two ways.
  1. Use ffmpeg to output the rtsp streams directly, so that you can use our sample directly
  2. Refer to our deepstream-appsrc-test sample, use appsrc plugin to to implement your needs. You need to control the reading of the video data yourself.
I want to generate short videos-up to 30 seconds- and send them to the queue.
Then you can only choose the second option, using appsrc plugin to implement that feature. Please refer to our deepstream-appsrc-test I attached before.
let me check it. I think I should create a new topic for specific question
