Reading 3D buffers on CPU
I’m working on ray-tracing applied to ultra-sonic wave simulation. The results OptiX produce are stored into a 3D buffer that is transferred to the CPU memory in order to be read by a C++ program.
My problem is the following : I don’t exactly know how to get the (x,y,z) element from my buffer once it’s mapped.
First, I wrote an accessor like this :
size_t global_id_element = x * n_y * n_z + + y * n_z + z;
It didn’t work so my new accessor is the following :
size_t global_id_element = x + n_x * (y + n_y * z);
Is it correct ?
Thanks,
Hamza
This depends on how you write the elements into the buffer in your OptiX programs.
Have a look at http://www.cplusplus.com/forum/beginner/2903/, hope this helps.
I agree with m_sch, it depends on how you decide to store elements inside the buffer.
I was just using the 3D launch index to write into my buffer :
buffer[launch_index] = data;
Anyway, what I wrote was correct, I checked it.
So it’s a “minor-first” array.
