• Hardware Platform (Jetson / GPU) = GPU RTX 2080Ti
• DeepStream Version = Deepstream-6.0
• NVIDIA GPU Driver Version (valid for GPU only) = 495.44
• Issue Type( questions, new requirements, bugs) = Question
**• How to reproduce the issue ? **
Hi, I’m a new to Gstreamer. I trying to read a .mp4 video through Gstreamer and want to process the frames using opencv.
I have pulled the deepstream-6.0 image and installed the python deepstream bindings, built opencv-python from source for python 3.8 and installed both the modules inside a virtual env.
The steps I followed for installing opencv-python from source.
git clone --recursive GitHub - opencv/opencv-python: Automated CI toolchain to produce precompiled opencv-python, opencv-python-headless, opencv-contrib-python and opencv-contrib-python-headless packages.
cd opencv-python
export CMAKE_ARGS="-DWITH_GSTREAMER=ON"
pip install --upgrade pip wheel
pip wheel . --verbose
pip install opencv_python*.whl
After the installation I was able to run the below code successfully
import cv2
cap = cv2.VideoCapture(‘autovideosrc ! videoconvert ! appsink’)
while True:
ret,frame = cap.read()
cv2.imshow(’’,frame)
if cv2.waitKey(1) & 0xFF == ord(‘q’):
break
cv2.destroyAllWindows()
cap.release()
with help of above reference code, I tried to create two different pipeline examples in gstreamer for reading .mp4 video and process it’s frames using opencv but getting same error for both the pipeline. I have attached the python code for your reference.
opencvpipeline.py (784 Bytes)
when I run the code I’m getting the following error:
[ WARN:0@0.308] global /opt/nvidia/deepstream/deepstream-6.0/sources/opencv-python/opencv/modules/videoio/src/cap_gstreamer.cpp (2402) handleMessage OpenCV | GStreamer warning: Embedded video playback halted; module qtdemux0 reported: Internal data stream error.
[ WARN:0@0.329] global /opt/nvidia/deepstream/deepstream-6.0/sources/opencv-python/opencv/modules/videoio/src/cap_gstreamer.cpp (1356) open OpenCV | GStreamer warning: unable to start pipeline
[ WARN:0@0.329] global /opt/nvidia/deepstream/deepstream-6.0/sources/opencv-python/opencv/modules/videoio/src/cap_gstreamer.cpp (862) isPipelinePlaying OpenCV | GStreamer warning: GStreamer: pipeline have not been created
Incase if both the pipelines are wrong can you suggest a pipeline for this issue? to read a .mp4 using gstreamer and process it’s frames using opencv in x86 machine
I have attached my cv2.getBuildInformation for your reference
General configuration for OpenCV 4.5.5 =====================================
Version control: 4.5.5
Platform:
Timestamp: 2022-04-08T08:54:26Z
Host: Linux 5.11.0-41-generic x86_64
CMake: 3.22.3
CMake generator: Unix Makefiles
CMake build tool: /usr/bin/make
Configuration: Release
CPU/HW features:
Baseline: SSE SSE2 SSE3
requested: SSE3
Dispatched code generation: SSE4_1 SSE4_2 FP16 AVX AVX2 AVX512_SKX
requested: SSE4_1 SSE4_2 AVX FP16 AVX2 AVX512_SKX
SSE4_1 (16 files): + SSSE3 SSE4_1
SSE4_2 (1 files): + SSSE3 SSE4_1 POPCNT SSE4_2
FP16 (0 files): + SSSE3 SSE4_1 POPCNT SSE4_2 FP16 AVX
AVX (4 files): + SSSE3 SSE4_1 POPCNT SSE4_2 AVX
AVX2 (31 files): + SSSE3 SSE4_1 POPCNT SSE4_2 FP16 FMA3 AVX AVX2
AVX512_SKX (5 files): + SSSE3 SSE4_1 POPCNT SSE4_2 FP16 FMA3 AVX AVX2 AVX_512F AVX512_COMMON AVX512_SKX
C/C++:
Built as dynamic libs?: NO
C++ standard: 11
C++ Compiler: /usr/bin/c++ (ver 7.5.0)
C++ flags (Release): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Wsuggest-override -Wno-delete-non-virtual-dtor -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -fvisibility-inlines-hidden -O3 -DNDEBUG -DNDEBUG
C++ flags (Debug): -fsigned-char -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Wsuggest-override -Wno-delete-non-virtual-dtor -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -fvisibility-inlines-hidden -g -O0 -DDEBUG -D_DEBUG
C Compiler: /usr/bin/cc
C flags (Release): -fsigned-char -W -Wall -Werror=return-type -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -O3 -DNDEBUG -DNDEBUG
C flags (Debug): -fsigned-char -W -Wall -Werror=return-type -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -Wno-long-long -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -msse -msse2 -msse3 -fvisibility=hidden -g -O0 -DDEBUG -D_DEBUG
Linker flags (Release): -Wl,–exclude-libs,libippicv.a -Wl,–exclude-libs,libippiw.a -Wl,–gc-sections -Wl,–as-needed
Linker flags (Debug): -Wl,–exclude-libs,libippicv.a -Wl,–exclude-libs,libippiw.a -Wl,–gc-sections -Wl,–as-needed
ccache: NO
Precompiled headers: NO
Extra dependencies: /usr/lib/x86_64-linux-gnu/libjpeg.so /usr/lib/x86_64-linux-gnu/libtiff.so /usr/lib/x86_64-linux-gnu/libz.so dl m pthread rt
3rdparty dependencies: libprotobuf ade ittnotify libwebp libpng libopenjp2 IlmImf quirc ippiw ippicv
OpenCV modules:
To be built: calib3d core dnn features2d flann gapi highgui imgcodecs imgproc ml objdetect photo python3 stitching video videoio
Disabled: world
Disabled by dependency: -
Unavailable: java python2 ts
Applications: -
Documentation: NO
Non-free algorithms: NO
GUI: GTK3
GTK+: YES (ver 3.22.30)
GThread : YES (ver 2.56.4)
GtkGlExt: NO
VTK support: NO
Media I/O:
ZLib: /usr/lib/x86_64-linux-gnu/libz.so (ver 1.2.11)
JPEG: /usr/lib/x86_64-linux-gnu/libjpeg.so (ver 80)
WEBP: build (ver encoder: 0x020f)
PNG: build (ver 1.6.37)
TIFF: /usr/lib/x86_64-linux-gnu/libtiff.so (ver 42 / 4.0.9)
JPEG 2000: build (ver 2.4.0)
OpenEXR: build (ver 2.3.0)
HDR: YES
SUNRASTER: YES
PXM: YES
PFM: YES
Video I/O:
DC1394: YES (2.2.5)
FFMPEG: YES
avcodec: YES (57.107.100)
avformat: YES (57.83.100)
avutil: YES (55.78.100)
swscale: YES (4.8.100)
avresample: YES (3.7.0)
GStreamer: YES (1.14.5)
v4l/v4l2: YES (linux/videodev2.h)
Parallel framework: pthreads
Trace: YES (with Intel ITT)
Other third-party libraries:
Intel IPP: 2020.0.0 Gold [2020.0.0]
at: /opt/nvidia/deepstream/deepstream-6.0/sources/opencv-python/_skbuild/linux-x86_64-3.8/cmake-build/3rdparty/ippicv/ippicv_lnx/icv
Intel IPP IW: sources (2020.0.0)
at: /opt/nvidia/deepstream/deepstream-6.0/sources/opencv-python/_skbuild/linux-x86_64-3.8/cmake-build/3rdparty/ippicv/ippicv_lnx/iw
VA: NO
Lapack: NO
Eigen: NO
Custom HAL: NO
Protobuf: build (3.19.1)
OpenCL: YES (no extra features)
Include path: /opt/nvidia/deepstream/deepstream-6.0/sources/opencv-python/opencv/3rdparty/include/opencl/1.2
Link libraries: Dynamic load
Python 3:
Interpreter: /root/Envs/py38/bin/python (ver 3.8)
Libraries: /usr/lib/x86_64-linux-gnu/libpython3.8.so (ver 3.8.0)
numpy: /tmp/pip-build-env-n4h88m9i/overlay/lib/python3.8/site-packages/numpy/core/include (ver 1.17.3)
install path: python/cv2/python-3
Python (for build): /root/Envs/py38/bin/python
Java:
ant: NO
JNI: NO
Java wrappers: NO
Java tests: NO
Install to: /opt/nvidia/deepstream/deepstream-6.0/sources/opencv-python/_skbuild/linux-x86_64-3.8/cmake-install
