In order to have nice integration between Windows desktops and our Linux cluster I write wrapper scripts to run ‘dos2unix controlfile.uci tempfile.uci’ and then run the Linux program with tempfile.uci as input. This works, but it is now starting to get complicated. I now have to open ‘tempfile.uci’ and extract out further supplementary files that also require ‘dos2unix’.
I was hoping for a compilation flag, but I have been unable to find anything, except for ‘run dos2unix…’.
In the User’s Guide http://www.pgroup.com/doc/pgiug.pdf it says ‘FORTRAN_OPT’ and crif. Of course this didn’t work. I then tried ‘crlf’ and this didn’t work either.
I am happy that I have a solution that will solve many problems for me.
Comments:
Fix the User’s Guide, please.
I would suggest that ‘crlf’ should be the default.
Though this isn’t a direct concern of mine, would be nice to handle Mac files also.
In the User’s Guide > http://www.pgroup.com/doc/pgiug.pdf > it says ‘FORTRAN_OPT’ and crif. Of course this didn’t work. I then tried ‘crlf’ and this didn’t work either.
Sorry about that. I noticed these two typos as well and reported them to our docs person. It should be fixed in the 8.1 User’s Guide.
I asked our chief compiler architect about this. He said they had considered making this the default awhile ago. However, since ‘crlf’ is a legitimate character sequence on Linux that does not always mean the same thing as newline, changing the default would have potentially adverse effects.
