Hi everyone,
I have configured imx219 driver for reading RAW8 data using single lane,but, when am reading data, driver generating following error.
Can anyone help me to over come it.
Note:
** Changes I did in device tree is **
1] num_csi_lane = 1
2] bus-width = 1
3] num_lane = 1
here I have attached trace log of it.
kworker/1:3-1883 [001] … 739.437936: rtcpu_string: tstamp:23510817706 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/1:3-1883 [001] … 739.437943: rtos_queue_send_from_isr_failed: tstamp:23510859014 queue:0x0bcb41f8
kworker/1:3-1883 [001] … 739.437944: rtos_queue_send_from_isr_failed: tstamp:23510859163 queue:0x0bcb8a60
kworker/1:3-1883 [001] … 739.437945: rtos_queue_send_from_isr_failed: tstamp:23510859315 queue:0x0bcba5e0
kworker/1:3-1883 [001] … 739.437946: rtos_queue_send_from_isr_failed: tstamp:23510859460 queue:0x0bcbb3a0
kworker/1:3-1883 [001] … 739.437947: rtos_queue_send_from_isr_failed: tstamp:23510859608 queue:0x0bcbc160
kworker/1:3-1883 [001] … 739.437950: rtcpu_vinotify_event: tstamp:23510865950 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:22203193440 data:0x10000000
kworker/1:3-1883 [001] … 739.437951: rtcpu_vinotify_event: tstamp:23511372152 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:22203319552 data:0x31000001
kworker/1:3-1883 [001] … 739.437952: rtcpu_vinotify_event: tstamp:23511372292 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:22203329664 data:0x10000000
kworker/1:3-1883 [001] … 739.437953: rtcpu_vinotify_event: tstamp:23511372457 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:22203338112 data:0x07020001
kworker/1:3-1883 [001] … 739.437955: rtcpu_vinotify_event: tstamp:23511372593 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:22203368800 data:0x31000002
kworker/1:3-1883 [001] … 739.496267: rtos_queue_peek_from_isr_failed: tstamp:23511880736 queue:0x0bcbcf78
kworker/1:3-1883 [001] … 739.661874: rtos_queue_peek_from_isr_failed: tstamp:23516880735 queue:0x0bcbcf78
kworker/1:3-1883 [001] … 739.773865: rtos_queue_peek_from_isr_failed: tstamp:23521880732 queue:0x0bcbcf78
kworker/1:3-1883 [001] … 739.941864: rtos_queue_peek_from_isr_failed: tstamp:23526880736 queue:0x0bcbcf78
kworker/1:3-1883 [001] … 740.109881: rtos_queue_peek_from_isr_failed: tstamp:23531880735 queue:0x0bcbcf78
kworker/1:3-1883 [001] … 740.165853: rtcpu_nvcsi_intr: tstamp:23533961251 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
kworker/1:3-1883 [001] … 740.165857: rtcpu_nvcsi_intr: tstamp:23533961251 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
kworker/1:3-1883 [001] … 740.165858: rtcpu_nvcsi_intr: tstamp:23533964570 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
kworker/1:3-1883 [001] … 740.165860: rtcpu_nvcsi_intr: tstamp:23533964570 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000006
kworker/1:3-1883 [001] … 740.165861: rtcpu_nvcsi_intr: tstamp:23533964570 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:12 status:0x00000002
kworker/1:3-1883 [001] … 740.165862: rtcpu_nvcsi_intr: tstamp:23533964570 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
kworker/1:3-1883 [001] … 740.165864: rtcpu_nvcsi_intr: tstamp:23533964570 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000006
kworker/1:3-1883 [001] … 740.165865: rtcpu_nvcsi_intr: tstamp:23533964570 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:12 status:0x00000002
kworker/1:3-1883 [001] … 740.165866: rtcpu_nvcsi_intr: tstamp:23533968027 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
kworker/1:3-1883 [001] … 740.165867: rtcpu_nvcsi_intr: tstamp:23533968027 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000006
kworker/1:3-1883 [001] … 740.165869: rtcpu_nvcsi_intr: tstamp:23533968027 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:12 status:0x00000002
kworker/1:3-1883 [001] … 740.165894: rtcpu_nvcsi_intr: tstamp:23533968027 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
kworker/1:3-1883 [001] … 740.165895: rtcpu_nvcsi_intr: tstamp:23533968027 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000006
kworker/1:3-1883 [001] … 740.165896: rtcpu_nvcsi_intr: tstamp:23533968027 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:12 status:0x00000002
kworker/1:3-1883 [001] … 740.165898: rtcpu_vinotify_error: tstamp:23533969713 tag:CSIMUX_STREAM channel:0x03 frame:0 vi_tstamp:23533964494 data:0x00000001
kworker/1:3-1883 [001] … 740.165900: rtcpu_vinotify_error: tstamp:23533970470 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:23533964573 data:0x00000001
kworker/1:3-1883 [001] … 740.165901: rtcpu_nvcsi_intr: tstamp:23533971296 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
kworker/1:3-1883 [001] … 740.165902: rtcpu_nvcsi_intr: tstamp:23533971296 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:12 status:0x00000002
kworker/1:3-1883 [001] … 740.165904: rtcpu_nvcsi_intr: tstamp:23533971296 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
kworker/1:3-1883 [001] … 740.165905: rtcpu_nvcsi_intr: tstamp:23533971296 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:12 status:0x00000002
kworker/1:3-1883 [001] … 740.165906: rtcpu_nvcsi_intr: tstamp:23533974669 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
kworker/1:3-1883 [001] … 740.165907: rtcpu_nvcsi_intr: tstamp:23533974669 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000006
kworker/1:3-1883 [001] … 740.165910: rtcpu_nvcsi_intr: tstamp:23533974669 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:12 status:0x00000002
kworker/1:3-1883 [001] … 740.165937: rtcpu_nvcsi_intr: tstamp:23533974669 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
kworker/1:3-1883 [001] … 740.165938: rtcpu_nvcsi_intr: tstamp:23533974669 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000006
kworker/1:3-1883 [001] … 740.165939: rtcpu_nvcsi_intr: tstamp:23533974669 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:12 status:0x00000002
kworker/1:3-1883 [001] … 740.165940: rtcpu_nvcsi_intr: tstamp:23533978027 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
kworker/1:3-1883 [001] … 740.165942: rtcpu_nvcsi_intr: tstamp:23533978027 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:12 status:0x00000002
kworker/1:3-1883 [001] … 740.165943: rtcpu_nvcsi_intr: tstamp:23533978027 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
kworker/1:3-1883 [001] … 740.165944: rtcpu_nvcsi_intr: tstamp:23533978027 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:12 status:0x00000002
kworker/1:3-1883 [001] … 740.165945: rtcpu_nvcsi_intr: tstamp:23533981392 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
kworker/1:3-1883 [001] … 740.165946: rtcpu_nvcsi_intr: tstamp:23533981392 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:12 status:0x00000002
kworker/1:3-1883 [001] … 740.165948: rtcpu_nvcsi_intr: tstamp:23533981392 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
kworker/1:3-1883 [001] … 740.165949: rtcpu_nvcsi_intr: tstamp:23533981392 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:12 status:0x00000002
kworker/1:3-1883 [001] … 740.165950: rtcpu_nvcsi_intr: tstamp:23533984757 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
kworker/1:3-1883 [001] … 740.165951: rtcpu_nvcsi_intr: tstamp:23533984757 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000002
kworker/1:3-1883 [001] … 740.165952: rtcpu_nvcsi_intr: tstamp:23533984757 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:12 status:0x00000002
kworker/1:3-1883 [001] … 740.165954: rtcpu_nvcsi_intr: tstamp:23533984757 class:CORRECTABLE_ERR type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
kworker/1:3-1883 [001] … 740.165955: rtcpu_nvcsi_intr: tstamp:23533984757 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000006
kworker/1:3-1883 [001] … 740.165956: rtcpu_nvcsi_intr: tstamp:23533984757 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:12 status:0x00000002
kworker/1:3-1883 [001] … 740.165957: rtcpu_nvcsi_intr: tstamp:23533986071 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000004
kworker/1:3-1883 [001] … 740.165958: rtcpu_nvcsi_intr: tstamp:23533988122 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:12 status:0x00000002
kworker/1:3-1883 [001] … 740.165960: rtcpu_nvcsi_intr: tstamp:23533988122 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:12 status:0x00000002
kworker/1:3-1883 [001] … 740.221906: rtcpu_vinotify_event: tstamp:23534158638 tag:CSIMUX_STREAM channel:0x03 frame:0 vi_tstamp:23533964494 data:0x00000001
kworker/1:3-1883 [001] … 740.221910: rtcpu_vinotify_event: tstamp:23534158785 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:23533964573 data:0x00000001
kworker/1:3-1883 [001] … 740.277898: rtos_queue_peek_from_isr_failed: tstamp:23536880736 queue:0x0bcbcf78
kworker/1:3-1883 [001] … 740.445872: rtos_queue_peek_from_isr_failed: tstamp:23541880735 queue:0x0bcbcf78
kworker/1:3-1883 [001] … 740.613872: rtos_queue_peek_from_isr_failed: tstamp:23546880735 queue:0x0bcbcf78
Thanks for your time
