I have a kernel that keeps producing results as they are available…
I want to see if some result is available on it… (just peek)…while the kernel is still executing…
Can I use another “stream” to copy the result-set and peek into it? (assuming hardware supports concurrent copy and exec).
The bottomline of my question is : Will another “stream” share the same context as the “executing kernel” ?
You can try, but I am 99% sure there are no guarantees in the concurrency model that it will work.
By definition, that is always the case - streams exist within a single context. But it doesn’t imply you can successfully do what you are asking about.
Say, I use “threadfence” kindaa memory fence functions…, I should be able to read back the intermediate results… no? (OR) Is this what u call “undefined behavior” ?
