Got following response after adding your changes
cctv-ola3@cctvola3:~$ export GST_DEBUG=2
cctv-ola3@cctvola3:~$ gst-launch-1.0 rtspsrc location=rtsp://admin:welcome123@10.218.10.22:554/Streaming/Channels/102 ! decodebin ! videoconvert ! video/x-raw,format=BGR ! fakesink
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://admin:welcome123@10.218.10.22:554/Streaming/Channels/102
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
Progress: (request) SETUP stream 0
Progress: (open) Opened Stream
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Progress: (request) Sending PLAY request
Progress: (request) Sent PLAY request
Opening in BLOCKING MODE
0:00:00.555802930 16463 0x7f680028f0 WARN v4l2 gstv4l2object.c:4408:gst_v4l2_object_probe_caps:<nvv4l2decoder0:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:00.555874181 16463 0x7f680028f0 WARN v4l2 gstv4l2object.c:2370:gst_v4l2_object_add_interlace_mode:0x7f580b2350 Failed to determine interlace mode
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
0:00:00.660062487 16463 0x7f680028f0 WARN v4l2 gstv4l2object.c:4408:gst_v4l2_object_probe_caps:<nvv4l2decoder0:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Unknown error -1
0:00:00.660154885 16463 0x7f680028f0 WARN v4l2 gstv4l2object.c:2370:gst_v4l2_object_add_interlace_mode:0x7f580b2350 Failed to determine interlace mode
0:00:00.661328189 16463 0x7f680028f0 WARN basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<videoconvert0> transform could not transform video/x-raw(memory:NVMM), format=(string)NV12, width=(int)640, height=(int)480, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)126/95, chroma-site=(string)jpeg, colorimetry=(string)bt601, framerate=(fraction)25/1 in anything we support
0:00:00.661555120 16463 0x7f680028f0 WARN basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<videoconvert0> transform could not transform video/x-raw(memory:NVMM), format=(string)NV12, width=(int)640, height=(int)480, interlace-mode=(string)progressive, multiview-mode=(string)mono, multiview-flags=(GstVideoMultiviewFlagsSet)0:ffffffff:/right-view-first/left-flipped/left-flopped/right-flipped/right-flopped/half-aspect/mixed-mono, pixel-aspect-ratio=(fraction)126/95, chroma-site=(string)jpeg, colorimetry=(string)bt601, framerate=(fraction)25/1 in anything we support
0:00:00.661607517 16463 0x7f680028f0 WARN GST_PADS gstpad.c:4226:gst_pad_peer_query:<decodebin0:src_0> could not send sticky events
0:00:00.661937992 16463 0x7f680028f0 WARN v4l2videodec gstv4l2videodec.c:1433:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder0> Duration invalid, not setting latency
0:00:00.662312895 16463 0x7f680028f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1054:gst_v4l2_buffer_pool_start:<nvv4l2decoder0:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:00.664698045 16463 0x7f680028f0 WARN basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<capsfilter1> transform could not transform video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3, profile=(string)main, pixel-aspect-ratio=(fraction)126/95, width=(int)640, height=(int)480, framerate=(fraction)25/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true in anything we support
0:00:00.664769713 16463 0x7f680028f0 WARN basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter1> warning: not negotiated
0:00:00.664836642 16463 0x7f680028f0 WARN basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter1> warning: not negotiated
WARNING: from element /GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstCapsFilter:capsfilter1: not negotiated
Additional debug info:
gstbasetransform.c(1415): gst_base_transform_reconfigure (): /GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstCapsFilter:capsfilter1:
not negotiated
0:00:00.666117760 16463 0x7f680028f0 WARN basetransform gstbasetransform.c:1355:gst_base_transform_setcaps:<capsfilter1> transform could not transform video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3, profile=(string)main, pixel-aspect-ratio=(fraction)126/95, width=(int)640, height=(int)480, framerate=(fraction)25/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true in anything we support
0:00:00.666157292 16463 0x7f680028f0 WARN basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter1> warning: not negotiated
0:00:00.666179272 16463 0x7f680028f0 WARN basetransform gstbasetransform.c:1415:gst_base_transform_reconfigure:<capsfilter1> warning: not negotiated
