I can determine the level with bottle photos. But I can’t do this in real time. The program is not working. Photo bottle level detection code and real-time bottle level detection code;
PHOTO BOTTLE LEVEL DETECTION
import cv2
from matplotlib import pyplot as plt
import imutils
bottle = cv2.imread("veri1/foto2.jpg")
bottle_gray = cv2.split(bottle)[0]
#blurlama işlemi
bottle_gray = cv2.GaussianBlur(bottle_gray, (7,7), 0)
#draw histogram
#plt.hist(bottle_gray.ravel(), 256, [0,256]); plt.show()
#manuel threshold
(T, bottle_threshold) = cv2.threshold(bottle_gray, 30.5, 250, cv2.THRESH_BINARY_INV)
#apply opening operation
kernel = cv2.getStructuringElement(cv2.MORPH_RECT, (5,5))
bottle_open = cv2.morphologyEx(bottle_threshold, cv2.MORPH_OPEN, kernel)
#find all contours
contours = cv2.findContours(bottle_open.copy(), cv2.RETR_EXTERNAL, cv2.CHAIN_APPROX_SIMPLE)
contours = imutils.grab_contours(contours)
bottle_clone = bottle.copy()
cv2.drawContours(bottle_clone, contours, -1, (255,0,0), 2)
#sort contours by area
areas = [cv2.contourArea(contour) for contour in contours]
(contours, areas) = zip(*sorted(zip(contours,areas),key = lambda a:a[1]))
#print contour with largest area
cv2.drawContours(bottle_clone, [contours[-1]], -1, (255,0,0), 2)
#draw bounding box, calculate aspect and display decision
(x, y ,w, h) = cv2.boundingRect(contours[-1])
aspectRatio = w / float(h)
if aspectRatio < 0.4:
cv2.rectangle(bottle_clone, (x,y), (x+w, y+h), (0,255,0), 2)
cv2.putText(bottle_clone, "Dolu", (x+10, y+20), cv2.FONT_HERSHEY_PLAIN, 1, (0,255,0), 2)
else:
cv2.rectangle(bottle_clone, (x,y), (x+w, y+h), (0,0,255), 2)
cv2.putText(bottle_clone, "Eksik", (x+10, y+20), cv2.FONT_HERSHEY_PLAIN, 1, (0,0,255), 2)
cv2.imshow("Bottle Threshold", bottle_threshold)
cv2.imshow("Decision", bottle_clone)
cv2.waitKey(0)
REAL-TIME BOTTLE LEVEL DETECTION (NOT WORKING)
import cv2
import numpy as np
import RPi.GPIO as GPIO
import time
import imutils
def gstreamer_pipeline(
capture_width=1280,
capture_height=720,
display_width=600,
display_height=400,
framerate=0,
flip_method=0,
return (
"nvarguscamerasrc ! "
"video/x-raw(memory:NVMM), "
"width=(int)%d, height=(int)%d, "
"format=(string)NV12, framerate=(fraction)%d/1 ! "
"nvvidconv flip-method=%d ! "
"video/x-raw, width=(int)%d, height=(int)%d, format=(string)BGRx ! "
"videoconvert ! "
"video/x-raw, format=(string)BGR ! appsink"
capture_width,
capture_height,
framerate,
flip_method,
display_width,
display_height,
cap = cv2.VideoCapture(gstreamer_pipeline(flip_method=0), cv2.CAP_GSTREAMER) # 6.- 31. arası kamera devreye al
while True:
_, frame = cap.read()
#hsv_frame = cv2.cvtColor(frame, cv2.COLOR.BGR2HSV)
bottle_gray = cv2.split(frame)[0]
bottle_clone = frame.copy()
bottle_clone1 = frame.copy()
cv2.drawContours(bottle_clone1, [contours[-1]], -1, (255,0,0), 2)
bottle_clone2 = frame.copy()
if aspectRatio < 0.9:
cv2.rectangle(bottle_clone2, (x,y), (x+w, y+h), (0,255,0), 2)
cv2.putText(bottle_clone2, "Dolu", (x+10, y+20), cv2.FONT_HERSHEY_PLAIN, 1, (0,255,0), 2)
else:
cv2.rectangle(bottle_clone2, (x,y), (x+w, y+h), (0,0,255), 2)
cv2.putText(bottle_clone2, "Eksik", (x+10, y+20), cv2.FONT_HERSHEY_PLAIN, 1, (0,0,255), 2)
#cv2.imshow("Bottle Threshold", bottle_threshold)
cv2.imshow("Decision", bottle_clone2)
cv2.waitKey(0)
cap.release()
cv2.destroyAllWindows()
Please help. Thanks in advance
