Real Time Clock Oscillator - Features and precision
As part of a development on Jetson TX2, our objective is to produce a timestamp on each image taken by a Sensor connected to the Jetson module.
We would need technical information regarding the crystal oscillator used which is internal to the module.
According to the datasheet:
“The Jetson TX2 series module requires no external clocks for operation, all system clocks are generated within the module; this includes a low power 32.768kHz system clock”.
Is it possible to have information regarding the low power 32.786kHz system clock. We would need:
  • Frequency Tolerance at 25°C (in ppm for example)
  • Maximum Deviation of frequency (in Hz)
Thank you very much.
It’s +/-20ppm @ 25C, no value of “maximum deviation of frequency”.
