I’m currently working on a drone project involving real-time object detection and am using a Jetson Nano 2GB Developer Kit as the onboard processing unit. However, I’ve run into a major roadblock: I’ve forgotten the Ubuntu 20.04 password for the device, which has effectively locked me out.
Here’s what I’ve attempted so far:
I tried the standard GRUB recovery key combinations (Shift, Shift+Esc) during reboot. Unfortunately, they just return me to the login screen — no GRUB menu appears.
I attempted to reflash the microSD card using Balena Etcher. I used the sd-blob.img file referenced in NVIDIA’s setup guide (link), but that file appears to be a component, not a full bootable image. The issue persists.
I reached out to local electronics repair shops (Best Buy, Micro Center, etc.), but they don’t service Linux-based hardware.
At this point, I’m open to any recommendations — either to fully reset the Jetson Nano or move to a different platform. If password recovery isn’t feasible, I’m considering alternative hardware like another NVIDIA board or a Raspberry Pi 4/5.
If you’ve had hands-on experience running AI workloads (e.g., real-time inference with YOLO or TensorRT) on local edge devices, I’d appreciate any insights on what platform you’d recommend for any application.
Thank you for your time.
