I have found an easier solution using centroid tracker
Please help me fix this
File “build_engine.py”, line 16, in
import uff
File “/usr/lib/python3.6/dist-packages/uff/init.py”, line 49, in
from uff.converters.tensorflow.conversion_helpers import from_tensorflow # noqa
File “/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/conversion_helpers.py”, line 59, in
from .converter_functions import * # noqa
File “/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/converter_functions.py”, line 59, in
from uff.converters.tensorflow.converter import TensorFlowToUFFConverter as tf2uff
File “/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py”, line 60, in
from tensorflow.compat.v1 import AttrValue
ModuleNotFoundError: No module named ‘tensorflow’
i am getting error while installing the dependencies. h5py and future is not installing it shows error. can you help me for this
Hello nisriniss311, did you find a solution? I have the same issue, but I remember I install this tool some years ago and work fine for me, then I used the nano for other application, so I delete all. Now, doesn’t work…
how many hours does it take ?
