I’m running Jetpack 4.3, and the realsense-camera app from the sample directory has similar issues
kaya@Kaya:~ **sudo jetson_clocks**
[sudo] password for kaya:
kaya@Kaya:~ sudo nvpmodel -m 0
kaya@Kaya:~ cd deploy/media/realsense_camera-pkg/
kaya@Kaya:~/deploy/media/realsense_camera-pkg ./apps/samples/realsense_camera/realsense_camera
2020-08-05 16:24:01.467 INFO engine/alice/tools/websight.cpp@166: Loading websight…
2020-08-05 16:24:01.468 WARN engine/alice/backend/application_json_loader.cpp@174: This application does not have an explicit scheduler configuration. One will be autogenerated to the best of the system’s abilities if possible.
2020-08-05 16:24:01.469 INFO engine/alice/backend/redis_backend.cpp@40: Successfully connected to Redis server.
2020-08-05 16:24:01.469 WARN engine/alice/backend/backend.cpp@201: This application does not have an execution group configuration. One will be autogenerated to the best of the systems abilities if possible.
2020-08-05 16:24:01.469 WARN engine/gems/scheduler/scheduler.cpp@337: No default execution groups specified. Attempting to create scheduler configuration for 4 remaining cores. This may be non optimal for the system and application.
2020-08-05 16:24:01.469 INFO engine/gems/scheduler/scheduler.cpp@290: Scheduler execution groups are:
2020-08-05 16:24:01.469 INFO engine/gems/scheduler/scheduler.cpp@299: BlockerGroup: Cores = [3], Workers = No
2020-08-05 16:24:01.469 INFO engine/gems/scheduler/scheduler.cpp@299: WorkerGroup: Cores = [0, 1, 2], Workers = Yes
2020-08-05 16:24:01.508 INFO engine/alice/backend/modules.cpp@226: Loaded module ‘packages/realsense/librealsense_module.so’: Now has 45 components total
2020-08-05 16:24:01.527 INFO engine/alice/backend/modules.cpp@226: Loaded module ‘packages/rgbd_processing/librgbd_processing_module.so’: Now has 51 components total
2020-08-05 16:24:01.544 INFO engine/alice/backend/modules.cpp@226: Loaded module ‘packages/sight/libsight_module.so’: Now has 54 components total
2020-08-05 16:24:01.567 INFO engine/alice/backend/modules.cpp@226: Loaded module ‘packages/viewers/libviewers_module.so’: Now has 83 components total
2020-08-05 16:24:01.567 DEBUG engine/alice/application.cpp@348: Loaded 83 components: isaac::RealsenseCamera, isaac::alice::BufferAllocatorReport, isaac::alice::ChannelMonitor, isaac::alice::CheckJetsonPerformanceModel, isaac::alice::CheckOperatingSystem, isaac::alice::Config, isaac::alice::ConfigBridge, isaac::alice::ConfigLoader, isaac::alice::Failsafe, isaac::alice::FailsafeHeartbeat, isaac::alice::InteractiveMarkersBridge, isaac::alice::JsonToProto, isaac::alice::LifecycleReport, isaac::alice::MessageLedger, isaac::alice::MessagePassingReport, isaac::alice::NodeStatistics, isaac::alice::Pose, isaac::alice::Pose2Comparer, isaac::alice::PoseFromFile, isaac::alice::PoseInitializer, isaac::alice::PoseMessageInjector, isaac::alice::PoseToFile, isaac::alice::PoseToMessage, isaac::alice::PoseTree, isaac::alice::PoseTreeJsonBridge, isaac::alice::PoseTreeRelink, isaac::alice::ProtoToJson, isaac::alice::PyCodelet, isaac::alice::Random, isaac::alice::Recorder, isaac::alice::RecorderBridge, isaac::alice::Replay, isaac::alice::ReplayBridge, isaac::alice::Scheduling, isaac::alice::Sight, isaac::alice::SightChannelStatus, isaac::alice::Subgraph, isaac::alice::Subprocess, isaac::alice::TcpPublisher, isaac::alice::TcpSubscriber, isaac::alice::Throttle, isaac::alice::TimeOffset, isaac::alice::TimeSynchronizer, isaac::alice::UdpPublisher, isaac::alice::UdpSubscriber, isaac::map::Map, isaac::map::ObstacleAtlas, isaac::map::OccupancyGridMapLayer, isaac::map::PolygonMapLayer, isaac::map::WaypointMapLayer, isaac::navigation::DistanceMap, isaac::navigation::NavigationMap, isaac::navigation::RangeScanModelClassic, isaac::navigation::RangeScanModelFlatloc, isaac::rgbd_processing::DepthEdges, isaac::rgbd_processing::DepthImageFlattening, isaac::rgbd_processing::DepthImageToPointCloud, isaac::rgbd_processing::DepthNormals, isaac::rgbd_processing::DepthPoints, isaac::rgbd_processing::FreespaceFromDepth, isaac::sight::AliceSight, isaac::sight::SightWidget, isaac::sight::WebsightServer, isaac::viewers::BinaryMapViewer, isaac::viewers::ColorCameraViewer, isaac::viewers::DepthCameraViewer, isaac::viewers::Detections3Viewer, isaac::viewers::DetectionsViewer, isaac::viewers::FiducialsViewer, isaac::viewers::FlatscanViewer, isaac::viewers::GoalViewer, isaac::viewers::ImageKeypointViewer, isaac::viewers::LidarViewer, isaac::viewers::MosaicViewer, isaac::viewers::ObjectViewer, isaac::viewers::OccupancyMapViewer, isaac::viewers::PointCloudViewer, isaac::viewers::PoseTrailViewer, isaac::viewers::SegmentationCameraViewer, isaac::viewers::SegmentationViewer, isaac::viewers::SkeletonViewer, isaac::viewers::TensorViewer, isaac::viewers::TrajectoryListViewer,
2020-08-05 16:24:01.570 WARN engine/alice/application.cpp@164: The function Application::findComponentByName is deprecated. Please use getNodeComponentOrNull
instead. Note that the new method requires a node name instead of a component name. (argument: ‘websight/isaac.sight.AliceSight’)
2020-08-05 16:24:01.570 INFO engine/alice/application.cpp@255: Starting application ‘realsense_camera’ (instance UUID: ‘bebf82d2-d772-11ea-aee2-5d24f609e236’) …
2020-08-05 16:24:01.570 DEBUG engine/gems/scheduler/execution_groups.cpp@476: Launching 0 pre-start job(s)
2020-08-05 16:24:01.570 DEBUG engine/gems/scheduler/execution_groups.cpp@485: Replaying 0 pre-start event(s)
2020-08-05 16:24:01.570 INFO engine/alice/backend/asio_backend.cpp@33: Starting ASIO service
2020-08-05 16:24:01.572 INFO packages/sight/WebsightServer.cpp@216: Sight webserver is loaded
2020-08-05 16:24:01.572 INFO packages/sight/WebsightServer.cpp@217: Please open Chrome Browser and navigate to http://:3000
2020-08-05 16:24:01.572 WARN engine/alice/backend/codelet_canister.cpp@225: Codelet ‘websight/isaac.sight.AliceSight’ was not added to scheduler because no tick method is specified.
2020-08-05 16:24:01.573 WARN engine/alice/components/Codelet.cpp@53: Function deprecated. Set tick_period to the desired tick paramater
2020-08-05 16:24:01.573 WARN engine/alice/backend/codelet_canister.cpp@225: Codelet ‘_check_operating_system/isaac.alice.CheckOperatingSystem’ was not added to scheduler because no tick method is specified.
2020-08-05 16:24:02.015 ERROR engine/alice/components/Codelet.cpp@229: Component ‘camera/realsense’ of type ‘isaac::RealsenseCamera’ reported FAILURE:
** RealSense error calling rs2_pipeline_start_with_config(pipe:0x7f640572f0, config:0x7f640d4950): Couldn’t resolve requests**
2020-08-05 16:24:02.015 ERROR engine/alice/backend/event_manager.cpp@42: Stopping node ‘camera’ because it reached status 'FAILURE’
2020-08-05 16:24:02.015 WARN engine/alice/backend/codelet_canister.cpp@225: Codelet ‘camera/realsense’ was not added to scheduler because no tick method is specified.
2020-08-05 16:24:11.570 INFO engine/alice/backend/allocator_backend.cpp@57: Optimized memory CPU allocator.
2020-08-05 16:24:11.570 INFO engine/alice/backend/allocator_backend.cpp@66: Optimized memory CUDA allocator.
2020-08-05 16:24:20.997 INFO packages/sight/WebsightServer.cpp@113: Server connected / 1
^C2020-08-05 16:25:03.648 INFO engine/alice/application.cpp@274: Stopping application ‘realsense_camera’ (instance UUID: ‘bebf82d2-d772-11ea-aee2-5d24f609e236’) …
2020-08-05 16:25:03.648 INFO engine/alice/backend/backend.cpp@134: Backend is shutting down…
2020-08-05 16:25:03.659 INFO packages/sight/WebsightServer.cpp@124: Disconnected
2020-08-05 16:25:03.659 INFO packages/sight/WebsightServer.cpp@450: =====================================================================================
2020-08-05 16:25:03.659 INFO packages/sight/WebsightServer.cpp@451: | Websight Statistics Report |
2020-08-05 16:25:03.659 INFO packages/sight/WebsightServer.cpp@452: =====================================================================================
2020-08-05 16:25:03.659 INFO packages/sight/WebsightServer.cpp@453: | Name | Bandwidth | Total | Count |
2020-08-05 16:25:03.659 INFO packages/sight/WebsightServer.cpp@454: -------------------------------------------------------------------------------------
2020-08-05 16:25:03.659 INFO packages/sight/WebsightServer.cpp@473: =====================================================================================
2020-08-05 16:25:03.669 INFO engine/alice/backend/asio_backend.cpp@49: Stopping ASIO service
2020-08-05 16:25:03.679 DEBUG engine/gems/scheduler/execution_groups.cpp@505: Stopping all threads for execution group BlockerGroup…
2020-08-05 16:25:03.679 DEBUG engine/gems/scheduler/execution_groups.cpp@509: Stopping all threads DONE
2020-08-05 16:25:03.679 DEBUG engine/gems/scheduler/execution_groups.cpp@505: Stopping all threads for execution group WorkerGroup…
2020-08-05 16:25:03.679 INFO engine/alice/backend/backend.cpp@149: Backend is shutting down… DONE
2020-08-05 16:25:03.679 INFO engine/alice/backend/backend.cpp@153: codelets:
| Job Statistics Report (regular) |
| Name | Count | Time (Median - 90% - Max) [ms] | Load (%) | Late (%) |
| isaac.alice.BufferAllocatorReport | 21 | 11.10 | 16.55 | 24.13 | 0.3 % | 0.0 % |
| isaac.alice.ConfigBridge | 1 | 1.19 | 1.19 | 1.19 | 0.0 % | 0.0 % |
| InteractiveMarkersBridge | 1242 | 0.04 | 0.06 | 2.29 | 0.1 % | 0.0 % |
| isaac.alice.LifecycleReport | 249 | 0.02 | 0.03 | 9.21 | 0.0 % | 0.0 % |
| isaac.alice.MessagePassingReport | 21 | 28.60 | 45.33 | 76.96 | 1.0 % | 0.0 % |
| PoseTreeJsonBridge | 1242 | 0.15 | 0.18 | 1.61 | 0.2 % | 0.0 % |
| NodeStatistics | 63 | 3.17 | 3.67 | 4.91 | 0.2 % | 0.0 % |
| depth_to_pointcloud | 0 | 0.00 | 0.00 | -inf | 0.0 % | 0.0 % |
| viewer | 0 | 0.00 | 0.00 | -inf | 0.0 % | 0.0 % |
| color | 0 | 0.00 | 0.00 | -inf | 0.0 % | 0.0 % |
| depth | 0 | 0.00 | 0.00 | -inf | 0.0 % | 0.0 % |
| left_ir | 0 | 0.00 | 0.00 | -inf | 0.0 % | 0.0 % |
| right_ir | 0 | 0.00 | 0.00 | -inf | 0.0 % | 0.0 % |
| WebsightServer | 11745 | 5.23 | 5.32 | 60.31 | 98.2 % | 0.0 % |
kaya@Kaya:~/deploy/media/realsense_camera-pkg$
Got to work the v4l2-ctl command, and this is the output:
kaya@Kaya:~$ v4l2-ctl --list-devices
Intel® RealSense™ Depth Ca (usb-70090000.xusb-2.3):
/dev/video0
/dev/video1
/dev/video2
kaya@Kaya:~$
any other advice?
