No enough bandwidth, that are 6 video streams. Try low the resolution and fps, or reduce the streams number as do not stream stereo, only rgb and depth. Be sure you are in the last version of realsense-sdk and firmware, a related issue was fixed in the last builds. I read the issue continued on realsense ros wrapper after be fixed in SDK, ask in their github if it is still without fix
