Skin and face is great just with defaults ( thanks Omniverse you just saved me 50 hours of tweaking! ) but hair geometry is not smooth.
CC support answered to me about this:
Thank you for contacting Reallusion.
The realtime sub-division in CC3 and iClone is a graphics card render-time feature. DirectX 11 is doing that for you in realtime at the rendering stage. The actual geometry of the model is not increased. So please check the Omniverse manual for a similar realtime sub-division feature. This is the same type of feature that Unreal and Unity use as well, and has to be turned on in each application.
Please feel free to let us know if you have any further questions.
Best Regards
Rampa
Technical Support
Reallusion Inc.
So how can I activate this kinda of realtime sub-division feature?
From manuals, I found that there is RTX settings / Common / Geometry / Subdivision Global Refinement Level
and
Subdivision Featrure-adaptive Refinement
It is a realtime-only function that happens during the render on the GPU. Hopefully someone in the Omniverse forum can help you more with activating the function.
CC support:
The sub-D is realtime only. It cannot be exported. Sorry. It is a DirectX rendering trick that many realtime engines take advantage of. Apparently Omniverse does not support the realtime tessalation.
Hair and fur coming from iclone or CC are low poly meshs, so its need a tesselation shader for RTX realtime render. for pathtracing its dont works . the guys from Marmoset developed your own tesselation for low poly meshs to render with path tracing, so i think is someone developers of the omniverse forget HAHAHAH. as i am new using ominverse is what i can say i discovering ominverse, but as unity user and with some experience using RTX raytracing on unity what i can say you need tesselation not subdivision. as subdvision will break the magic of the speed of a game engine. tessealtion is used in realtime engines for years i suprised if this not exists in ominverse
i believe it only works with static meshs not with skined meshs, btw is a beta, i dont care for now, i just playing with that like a toy when have time, and reporting regular bugs.
