JetPack 5.1.4
Aug 13 15:48:26 lite-0037 kernel: [ 0.633260] tegra-pmc: ### PMC reset source: SYS_RESET_N
Aug 13 15:48:26 lite-0037 kernel: [ 0.633262] tegra-pmc: ### PMC reset level: L0
Aug 13 15:48:26 lite-0037 kernel: [ 0.633263] tegra-pmc: ### PMC reset status reg: 0x0
SYS_RESET_N 这个标志的重启原因是什么?
谢谢!
hiwata
August 17, 2026, 12:48am
4
This log indicates that the SoM’s SYS_RESET signal was driven low by the carrier board, causing a system reset.
Thank you,
Our device’s reset pin is not controlled by other devices
Is this sign indicating that it has been powered off and restarted?
Thank you,
hiwata
August 17, 2026, 2:05am
6
Could you clarify under what condition this log was captured? Was it observed during a normal power on boot, or after an unexpected reboot while the system was operating?
Unexpected system restart, PMIC log
Do you have the log prior to this reset from your UART serial console?
The serial port log is missing
我看/var/log/目录下的kern.log, 是没有kernel crash或者panic的log。
因为我自己手动断电和执行reset操作,pmic会打印 SYS_RESET_N。我不知道还有在什么情况pmic会打印相关的LOG( SYS_RESET_N)
I think the system crash is the most common reason behind this.
我手动触发过kernel crash,但是 不是这个标志 SYS_RESET_N。我现在不确认什么场景会打印这个LOG Aug 13 15:48:26 lite-0037 kernel: [ 0.633260] tegra-pmc: ### PMC reset source: SYS_RESET_N
Have you checked the thermal condition before issue happened?
没有的 有PMC reset source: SYS_RESET_N介绍的文档吗?
