Rebuilding nvinfer plugin
I wish to know whether the linbvinfer.so lib which comes with the deepstream sdk is same as that what we get after manually building and generating the lib from the source code which comes for nvinfer in deepstream sdk ? Or is there any difference. Will the performance remain the same, if I build the plugin from source present in ‘sources/gst-plugin/gst-nvinfer’ directory ?
Yes. It’s the same.
