Receive video from IMX219 through single lane
I want to receive the video from imx219 sensor using 1 lane. Using jetson-io.py file, successfully received video from imx219 using 2 lane in jetson xavier nx.
I am using jetpack 4.6.5 and bsp 32.7.5.
what are all the settings to be change in the previous device driver and device tree of imx219?
May i know, is it possible to receive?
Feel free to ask questions.
Regards,
Dhoom
Two lanes working well why need one lane configuration?
You need one lane sensor REG configuration and modify the bus-width to 1 in device tree.
Hi shaneCCC,
I want to evaluate the video performance of the NX when it receives data through a single lane from the IMX219 camera. How will the video frames behave in this configuration? This is why I need to work with a single lane setup.
Please correct me if I am wrong.
I need to configure the single lane registers in the imx219_reg_tbls.h file.
Where can I find the single lane register configuration?
Regards,
Dhoom
Yes, you need confirm with vendor for the necessary REG modification in sensor initialize REG table.
Hi Shane,
Actually, I have a doubt. Let’s say the camera outputs over 2 lanes, but I need to receive it using only 1 lane on the Xavier NX. Is that possible?
In this case, I don’t need to change the register settings, correct?
Regards,
Dhoom
It’s impossible for sensor output by 2 lanes configurate but NVCSI receive by 1 lane. I don’t think there are any platform able to support it too.
Thank you for your clarification and support.
Regards,
Dhoom
