I am using the following code to perform distortion correction on input RGB8 image (width:1280, height:720)
param_videoOutput = []
param_videoOutput.append("--width=" + str(1280))
param_videoOutput.append(f"--height=" + str(720))
input = videoSource('file:///home/front_video.mp4')
output = videoOutput('display://0', argv=param_videoOutput)
while True:
image = input.Capture(format='rgb8')
if image is None:
continue
with vpi.Backend.CUDA:
distortion_corrected_front = vpi.asimage(image)\
.convert(vpi.Format.NV12_ER)\
.remap(warpmap_distortion_correction, interp=vpi.Interp.NEAREST)\
.convert(vpi.Format.F32)
distortion_corrected_cpu = distortion_corrected_front.cpu()
print(distortion_corrected_cpu.shape)
This code prints (720, 1280) as opposed to (720,1280,3). When I copy the vpi image into a numpy array, the shape of the numpy array is (720, 1280) as opposed to (720, 1280, 3). When I change the vpi pipeline to .convert(vpi.Format.RGB8)
instead in the end, I get a numpy array with shape (720, 1280, 3). How can I get a F32 format vpi image that has 3 channels? The reason I want to use F32 format is to pass the image to a numba cuda kernel.
Kindly advice.
