Recommendation for IMX219 sensors
I am building a Xavier NX based CCTV and purchased an IMX219 sensor (IMX219-120) from Waveshare. I am taking 3280 × 2464 frames from the sensor using gstreamer. Unfortunately, I found that although the resolution is high, the quality of the videos are not good due to a lot of noise.
I would like to ask if there are any ways to reduce the noise? either using a software way or a hardware way? or any recommendations for IMX219 (~120 degrees) sensors which produce less noise?
Cheers,
Max
Which release BSP?
Have you try the argus_camera to check those setting from the GUI interface like noise reduction…
We are using L4T 32.4.3
Have a check argus_camera and maybe upload a picture maybe help to clear the problem.
