I’ve recently begun experimenting with executing a mass flash generated using the nvmassflashgen script. It took approximately 45min to flash four boards simultaneously using a single flashing host.
When examining the output of top
, I didn’t notice any resource constraints that would present an obvious bottleneck for the speed of the flash process, so I’m wondering:
How can we improve our procedure and/or hardware selection to speed up the mass flash operation?
To provide some context:
The mass flash tarball was initially created using the -r
flag, and the provided system.img
was a raw system image created using the flash.sh
script. The system.img
file has a size of approximately 28G.
Two boards were connected to the USB3.0 ports directly on the host, and two boards were connected to USB3.0 ports exposed by a USB-C hub attached to the host.
